Door Locks
I've got a 1997 F-250 that as soon as you put it in gear to go forward, the doors lock as is the norm on these "new" vehicles. My complaint is that when you stop an get out, the drivers side unlocks, BUT the passenger side doesn't. THEN invariably I go around to get something out of the passenger side and its LOCKED. Thats when my blood pressure goes into orbit. A trip to my dealer yielded no cigar. He stated that some models could be tricked into unlocking, but not this one. HEEELP
Thanks Irv
You could always turn the autolock off.
I just use my keyfob to unlock it if I forget to hit the unlock button when I get out (my door lock cylinder is messed up on the pass side so I can't use a key).
Irv
Deactivating/activating the autolock feature
all vehicle doors and the liftgate window are closed.
You must complete steps 1-7 within 30 seconds or the procedure will
have to be repeated. If the procedure needs to be repeated, you must
wait 30 seconds.
1. Turn the ignition key to RUN.
2. Press the power door unlock control three times.
3. Turn the ignition key from RUN to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to RUN. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
Hot diggety dog, your instructions worked. Thank you very much!
I looked at my owners manual after I saw your reply and there's no mention of that procedure in mine that I could find.
Now I won't have to grumble every time I try to get in!! Yee Haw
Thanks again.
Irv
