Sponsored by: Real Truck
auto lock disable
Old Jul 13, 2011 | 10:51 AM
jocko165's Avatar
jocko165
auto lock disable
my 02 250 has the deal where when you start driving it automatically locks all the doorsw and i HATE that. is there a way to disable this feature?
Old Jul 13, 2011 | 01:34 PM
jwako1's Avatar
jwako1
I used to hate it until I started having kids, now I see it like extra protection for the little ones. I'm sure there's a way to bypass that function.
Old Jul 14, 2011 | 05:07 PM
Wagion's Avatar
Wagion
There is a way or there use to be it is one of those turn ignition on off so many times lock unlock doors do the hokey pokey
Did you look in owners manual?
Old Jul 14, 2011 | 05:21 PM
Wagion's Avatar
Wagion
Deactivating/activating the autolock feature
Before following the procedure, make sure that the ignition is OFF and
all vehicle doors are closed.
You must complete steps 1-7 within 30 seconds or the procedure will
have to be repeated. If the procedure needs to be repeated, you must
wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
Old Jul 14, 2011 | 05:22 PM
Wagion's Avatar
Wagion
http://www.motorcraftservice.com/pub.../02f23og5e.pdf
Link to online owners manual for your truck
Old Nov 27, 2014 | 07:24 PM
Super Duty DJ's Avatar
Super Duty DJ
wait 30 seconds.
Thanks for posting this procedure. It still works this way on my 2015, which should have had a menu item in the information center, but didn't.
Old Oct 26, 2015 | 05:18 PM
slowlanemcvane's Avatar
slowlanemcvane
Just did this, worked like a charm. Thanks, this feature drives me nuckin' futs, and has for the better part of the 18 months that I've owned the truck.
Old Oct 26, 2015 | 06:36 PM
airm4n's Avatar
airm4n
My 2011 f350 with display center by speedometer has the option for autolocks on or off.
Krabill
Oct 8, 2024 04:52 PM
DOOM173
Jun 26, 2017 08:09 PM
phnguyk
Mar 14, 2016 07:47 PM
speed
Large Truck
Jan 20, 2016 11:11 PM
Vinford
Dec 8, 2015 08:14 PM
