Minnesota Chapter Join Chapter, Leader: fordpower88
December - chattering teeth BS Thread
Old Dec 16, 2014 | 01:43 PM
  #406
Big-Foot's Avatar
Big-Foot
Some pretty impressive results - would like to see some of the other parameters, but not being a diesel tuning expert, it may be lost with me...
I am curious about the long-term viability of engines that are pushed past their designed limits like this. IE - it might be nice or fun to "push the button" every now and again, but do these engines really perform at that level long term when being pushed?
I know with my old motorhome (1999) that had a CAT3216B in it - it produced 275 HP and couple be chipped to build 500+ HP, but the cooling system would not support more than 400 HP and the engines would overheat and blow head gaskets. What are the limits or tolerances on these trucks today? Same for the transmission cooling systems since you know that torque convertor is going to be smoking hot...
I'm more or less an old school wrench when it comes to diesels.. I learned on the old 2 stroke Detroits we had in the Navy back in 1970-71 which were put into service in the 40's... I love where technology has taken diesels, but at the same time, they've made their control systems extremely complex. The basics will always be the same - and there's some comfort in that...
Old Dec 16, 2014 | 03:26 PM
  #407
fordpower88's Avatar
fordpower88
Cory here is a car to replace that smashed up Buick you got!
2005 Ford Crown Victoria Police pkg w extras
Old Dec 16, 2014 | 04:32 PM
  #408
DieselCamper01's Avatar
DieselCamper01
Busy afternoon trying to catch up after bringing mom to the dr. Blah....
Old Dec 16, 2014 | 04:38 PM
  #409
dlibson's Avatar
dlibson
Get your computer up and going at least?
Old Dec 16, 2014 | 05:11 PM
  #410
wildstang's Avatar
wildstang
VT Chapter Ldr
What do you need to do to your newer truck to become your main one? Or is it already?
Old Dec 16, 2014 | 06:06 PM
  #411
dlibson's Avatar
dlibson
It's good to go basically. It'll need some airbags come camper towing season.
Old Dec 16, 2014 | 06:13 PM
  #412
MisterCMK's Avatar
MisterCMK
A 2 stroke Detroit? Like this?
Steiger Tractor 12V71 Detroit:
Sent from my Telegraph using IB AutoGroup
  #413
MisterCMK's Avatar
MisterCMK
That's what all these trucks put down with the same setup. Add some injector work and turbo upgrade in and it gets nuts. Already puts out 40 lbs of boost...
Chris, I got them balanced. I would guess they put tires on without balancing at all...
I bet it runs nice and smooth down the highway now!
Old Dec 16, 2014 | 06:16 PM
  #414
MisterCMK's Avatar
MisterCMK
So, 19k and you have a truck that is more than capable of pulling a 5th wheel and you aren't wrenching on it every day???
And makes 400hp with ease?
But shouldn't working under the valve covers be a weekly event? Oh wait...
Old Dec 16, 2014 | 06:25 PM
  #415
dlibson's Avatar
dlibson
Well, that and tires, and shocks, and vibrations, and noises, and transmissions, and leaks, and, and, and...
Old Dec 16, 2014 | 06:39 PM
  #416
Big-Foot's Avatar
Big-Foot
That's a doggoned good looking rig, I have bumper envy for sure... Those tires look ugly to balance... Ever thought of those beads? A coupla guys here swear by them. I have no idea how they would work with a tread pattern that agressive though...
Old Dec 16, 2014 | 06:43 PM
  #417
Big-Foot's Avatar
Big-Foot
Steiger Tractor 12V71 Detroit: Steiger Tractor 12V71 Detroit - YouTube
Mostly the 6-71 and 8-71, but yeah...
I was an Engineman (Diesel Mechanic) after I got hurt and retrained. I earned my Journeyman certificate there.. That was wayyyyy before there was ever an ASE program....
Old Dec 16, 2014 | 06:44 PM
  #418
dlibson's Avatar
dlibson
I've used those beads plenty. Use them on big tires 19.5-24.5s. They would work okay on these tires still. The main benefit to the beads is they are static, so they constantly keep balance even as the tires wear. I got them balanced up pretty well, though I have a couple of not perfectly round wheels in the back. There is no vibration now. Well, other then what the tires give based on the tread. I actually thought I'd swap them out right away expecting then to be way loud on the road, but they actually aren't that bad.
Old Dec 16, 2014 | 07:07 PM
  #419
DieselCamper01
It is up and running. Just need to get all my files back from the old hard drive.
Old Dec 16, 2014 | 07:20 PM
  #420
dlibson's Avatar
dlibson
That's good, part of the way there at least.
