Minnesota Chapter Join Chapter, Leader: fordpower88
December - chattering teeth BS Thread
Old Dec 16, 2014 | 06:50 AM
  #391
dlibson's Avatar
dlibson
Little bit of both Jim as far as MPGs though I averaged close to 16 driving 75-80. Played with the tuner some and was certainly not easy on it. It was fun. 650+ HP and 1100+ ft/lbs is fun!
No troubles once the drive started at all. Truck did have a bad alternator when we got there, but they took care of it for me.
Old Dec 16, 2014 | 07:02 AM
  #392
MisterCMK's Avatar
MisterCMK
And the out of balance tires haha
Sent from my Telegraph using IB AutoGroup
Old Dec 16, 2014 | 07:47 AM
  #393
fordpower88's Avatar
fordpower88
Originally Posted by Big-Foot
Good morning Minnesota....
It's Tuesday and we're getting close to the hump!!!!!
Mike - good luck with your son!
Dave - where's the pics of you and your new truck?
Have a good one boys!!!
Good morning Randy!
Originally Posted by dlibson
Good morning everyone!!!
Randy, maybe I'll snap a few today.
Good morning Dave!
Originally Posted by wildstang
So no problems on the drive back I assume. Do any mpg testing on the drive back or play with the programmer?
Good morning Jim!
That is pretty good mpg at those speeds! Where did you get the HP numbers from? I am guessing it must have been dynoed at some point and you got the paperwork.
Good morning Chris!
Old Dec 16, 2014 | 07:55 AM
  #394
Big-Foot's Avatar
Big-Foot
Wow - did they actually have dyno sheets to prove out those numbers???
Glad you got the alternator diagnosed and repaired....
This doesn't sound like the same truck that they advertised on eBay - or is it not "that" truck?
Old Dec 16, 2014 | 09:19 AM
  #395
DieselCamper01's Avatar
DieselCamper01
Morning guys. Slowly trying to get the new computer set up. Ugh!
Old Dec 16, 2014 | 09:22 AM
  #396
fordpower88
Good morning Jay! That sucks about the work computer. I am sure making your job this week a big PITA!
Old Dec 16, 2014 | 10:02 AM
  #397
dlibson's Avatar
dlibson
That's what all these trucks put down with the same setup. Add some injector work and turbo upgrade in and it gets nuts. Already puts out 40 lbs of boost...
Chris, I got them balanced. I would guess they put tires on without balancing at all...
Old Dec 16, 2014 | 10:03 AM
  #398
dlibson's Avatar
dlibson
Nope, same truck.
Old Dec 16, 2014 | 10:06 AM
  #399
Ford79's Avatar
Ford79
Good morning everyone. That white crap decided to show up again......... I was getting used to spring.
Thanks Randy.
Old Dec 16, 2014 | 10:13 AM
  #400
fordpower88
Well that is impressive to almost double the horsepower with just the basic mods. Hard to believe but very cool! Might need tires soon! haha
Thanks Randy.
Good morning Mike! Yep we knew it was too good to be true.
Old Dec 16, 2014 | 10:22 AM
  #401
wildstang's Avatar
wildstang
VT Chapter Ldr
You are such a negative Nellie
Old Dec 16, 2014 | 10:46 AM
  #402
fordpower88
Why what did I say that was negative? The fact that I said it was I said that it was hard to believe? I said it was very cool after that and said it was impressive as well. Sorry if you took it wrong.
Old Dec 16, 2014 | 11:11 AM
  #403
wildstang's Avatar
wildstang
VT Chapter Ldr
Only kidding, that is all. Just playing off the "hard to believe" portion. you know like a lawyer, take the portion that I can use for evil
Old Dec 16, 2014 | 12:02 PM
  #404
Big-Foot's Avatar
Big-Foot
Having built many engines for both racing and street use, I'm always skeptical of "Recipe" engines.. IE, this combination (recipe) always makes X-HP and Y-TQ... Too many variables to really make that happen consistently..
Not to say yours won't make those numbers, but it would be good to actually put it on a dyno to test it out and confirm that everything is okay. Many large diesel shops that I worked with in Texas did a dyno test to confirm that the fuel and air management systems were functioning properly - particularly after an injector or pump overhaul / replacement..
All that said, if it's got all the 'Nads you want and it serves your needs - great!
Old Dec 16, 2014 | 12:44 PM
  #405
dlibson's Avatar
dlibson
I hear ya Randy, and some day here I will get it on a dyno and live tuned. But I've seen hundreds with this same setup. Here is a dyno H&S put out with a smaller tune then I am using...
