Minnesota Chapter Join Chapter, Leader: fordpower88
December - chattering teeth BS Thread
Old Dec 13, 2014 | 10:56 PM
  #346
Big-Foot's Avatar
Big-Foot
When we got 14" of wet snow last winter, I had to take 3 passes at it with my Jeep...
I tried dropping the plow all the way and pushing off to the side but did not have enough traction / weight to move it more than 10' or so before I just sat and spun the tires.
Lifted the plow up and backed up.
Took a run at it with the plow lifted and angled - I ran the length of the driveway (about 200') to push the top 4" off to the side and driving through 10" with the tires and almost didn't make it to the end of the driveway.
Backed up in my tracks, dropped the plow and then lifted it about 5" and hit it again and did the same thing.
Backed up in my tracks again and dropped the plow to the ground and made it most the way but stalled out about 25 feet from the end..
Backed up about 30', put it in low range and gave it hell.. Made it!!!
I had to let the transmission cool a while in neutral about 1500 RPM, then spend the next 2 hours whitteling away at it until I had the driveway cleared...
I have to say that my little 3200# Wrangler did a good job for what it is, but snow like that was truly out of the league of that setup...
Old Dec 14, 2014 | 07:03 AM
  #347
wildstang's Avatar
wildstang
VT Chapter Ldr
I had to keep pushing it off to the side. The explorer is close to 4000 lbs so that helps. And its standard but the only negative is slower backing up
Old Dec 14, 2014 | 08:05 AM
  #348
Big-Foot's Avatar
Big-Foot
Good morning Jim and the rest of you Minnesota guys.... One last warm day before we go down down down in temps....
Jim - the Blizzak tires I have on the Jeep are Okay but I think what I really need are some good old fashioned Mud & Snow tires...
Old Dec 14, 2014 | 08:14 AM
  #349
MisterCMK's Avatar
MisterCMK
That Explorer has to be closer to 4500
Sent from my Telegraph using IB AutoGroup
Old Dec 14, 2014 | 09:35 AM
  #350
DieselCamper01's Avatar
DieselCamper01
Good morning guys.
I am jealous Jim. Our snow is completely gone here now and another 50*+ days today.
Not to be an **** Randy but you could have had your driveway cleared in under an hour with a good old fashioned snowblower.
Old Dec 14, 2014 | 09:53 AM
  #351
Big-Foot's Avatar
Big-Foot
Sorry Jay - you're wrong in this case. My neighbor's John Deere tractor with 4' blower couldn't make it through this stuff without continually plugging up the chute. Neighbor on the other side used his two stage 10hp unit and was at it all afternoon and he finally got an 8' path cleared from his garage to the street.
This stuff was wet and heavy as it came down and the temps dropped to the mid teens which made it like plowing cement as Jim was pointing out with the snowfall he just had to deal with..
One older barn just down the road had part of the roof cave in. Luckly only machinery in it.
It was good for the sledders and cross country skiers in the area, but that's about it..
Old Dec 14, 2014 | 05:28 PM
  #352
MisterCMK's Avatar
MisterCMK
So, time to look at jobs and such in Texas? Right Dave?
Old Dec 14, 2014 | 07:26 PM
  #353
wildstang's Avatar
wildstang
VT Chapter Ldr
Originally Posted by DieselCamper01
Good morning guys.
There is 9" of snow you can walk on without sinking. My trailer had 15" on it but around 10-11 on the ground. The only draw back is there really isn't any frost in the ground so still sticky on the bottom. Tuesday and Wednesday look to be upper 30's to mid 40's then cool back down. Going to be lots of trees to clean up
Old Dec 14, 2014 | 08:35 PM
  #354
MisterCMK's Avatar
MisterCMK
There is a small pile of snow in my yard still.
Old Dec 14, 2014 | 09:31 PM
  #355
dlibson's Avatar
dlibson
Sounds like a plan to me.
Old Dec 14, 2014 | 10:00 PM
  #356
wildstang's Avatar
wildstang
VT Chapter Ldr
Looks like slightly over 4000 but with plow and me in it it probably is close to 4500
Old Dec 14, 2014 | 10:01 PM
  #357
MisterCMK's Avatar
MisterCMK
My Explorer without a plow was close to 4500lb
Old Dec 14, 2014 | 10:06 PM
  #358
wildstang's Avatar
wildstang
VT Chapter Ldr
First generation 5 speed? Did you actually weigh it? I think the second and up generation probably were close to that.
Old Dec 14, 2014 | 10:09 PM
  #359
MisterCMK's Avatar
MisterCMK
1st gen with an automatic. Yup, I weighed it.
Old Dec 15, 2014 | 04:01 AM
  #360
wildstang's Avatar
wildstang
VT Chapter Ldr
Good morning and have a fast trouble free day MN
