turn signal switch
Old Nov 26, 2014 | 08:28 PM
69issofine's Avatar
69issofine
turn signal switch
i can get a new turn signal switch but the rest is missing like the little canceling cam and the copper button for the horn. when i got the truck all this was missing and the p.o. used hand signals and finger gesters the signal with, i don't intend to do that all the wrecking yards around here are missing these parts or they are broken because someone broke them trying to get them out. i am also looking for a long bed because my old one is rusted out on the bottom or would it be easier to fiberglass the bottom.i am pretty sure i would have to cut out the rust first but i can do all of that once the bed is off.
Old Nov 26, 2014 | 08:50 PM
ultraranger's Avatar
ultraranger
I recently bought a new turn signal switch for the tilt column I put in my '69 F-100. Since its for a tilt column, it's more expensive than a switch for a fixed column. It came with the turn signal cancelling cam.
You are probably much better off ponying up the money for a new switch. The plastic of an old one is likely going to be brittle. If a used one isn't broken when you put it on, it probably will be shortly there after and you'll be taking things apart again to replace it, yet again.
When you install the replacement turn signal switch, put a little white lithium grease on the arms of the cam. This will make it smoother and last longer.
51camohunter
23
Jul 9, 2023 12:25 PM
dakonthemountain
19
Dec 12, 2008 01:33 PM
jsutton
Jan 15, 2008 02:01 PM
buffystanley
Feb 25, 2006 07:32 PM
Bowtie's gone
Mar 22, 2005 03:25 PM
