Wiring questions?
Old Nov 16, 2014 | 03:28 PM
Gigemags05's Avatar
Gigemags05
Wiring questions?
I am dropping a 351w into my truck and replacing all headlights, taillights, electric fuel pump, horn, turn signals, etc.
So I will need to run all new wiring. I don't have any usable connectors or wiring.
Is there a kit that you all recommend? Maybe a painless kit or something similar?
I see that speedway has some wiring kits that include "GM column connectors." Did ford use a gm column or will those connectors work for my 82 column?
Old Nov 16, 2014 | 03:49 PM
ctubutis's Avatar
ctubutis
Originally Posted by Gigemags05
Did ford use a gm column...
No.
...or will those connectors work for my 82 column?
I really doubt it - unless GM used Ford-made connectors.
Old Nov 16, 2014 | 04:30 PM
Gigemags05's Avatar
Gigemags05
Ok. We worked on some other vehicles that used gm columns. Scouts and jeeps though.
Old Nov 16, 2014 | 07:56 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Any of the "hot rod" kits could be used. Simply a matter of finding one to suit your needs. Painless kits are OK, but not exactly painless on your wallet. Ron Francis makes an excellent product, but again pricey. I put many EZ Wire kits into customer's cars years ago. It was a good product and reasonably priced, but I have not kept up with it. Look for GXL wire and a compact fuseblock. Those GM style fuseboxes are a pain to mount.
As to GM column connectors, you may find many kits with unfinished ends for the ignition switch. Usually the manufacturers instruction tell you how to splice into a customer supplied ignition switch. I recall mounting a GM switch on a Ford column. Not necessarily an improvement and it took some ingenuity, but it did work and it solved the GM ignition switch connector problem. Long time ago and I've probably forgot the details.
Easiest fix would be to simply find a replacement harness for your truck. Nothing really wrong with the factory wiring unless someone has hacked it up. Also watch out for corroded and overheated fusebox connections. Pretty easy to spot and fix while the harness is out.
Old Nov 16, 2014 | 08:31 PM
Franklin2's Avatar
Franklin2
Those hot rod kits are not very good for our uses. If you are going to use any of the original switches and components that are found in these trucks, nothing is going to plug in. They basically give you a new fuse box (which is generic) and pieces of labeled wiring leaving this fuse box with blunt cut ends. If you did have your old harness, you would have to cut it at each connector and solder the new generic wiring onto the old plugs and short pieces of wire. And where do most of the problems occur in these old harnesses? You guessed it, the connectors.
You might has well patch up your old harness, it's really the only solution that makes any sense. Unless you are going to make a true hotrod out of it, using all generic switches and sockets.
Old Nov 16, 2014 | 09:46 PM
Gigemags05's Avatar
Gigemags05
Well, the vehicle I'm putting the engine into is a 1947 ford half ton. The reason i posted on this thread is because it's an 82 engine.
I don't have the original harness. The donor vehicle's wiring was so hacked up that I couldn't use any of it at all.
Old Nov 16, 2014 | 09:54 PM
Trackerrrr's Avatar
Trackerrrr
You could also pull a complete harness from a junkyard truck too.
Old Nov 17, 2014 | 07:01 AM
NotEnoughTrucks2014
Well, that changes everything.
Go for the hot rod harness. Consider using a GM column if you can find one.
Post should have gone into the truck year, not the engine year.
Old Nov 17, 2014 | 11:14 AM
Gigemags05's Avatar
Gigemags05
Sorry about that. I will post it in the other forum.
Everyone has been very helpful on this forum with all of my 351w questions so I never even thought to post it over there.
Old Nov 17, 2014 | 04:36 PM
RL250's Avatar
RL250
Don't feel bad. I do the same thing. I'm planning a 351W swap into a Nissan Xterra, so I'm planning to go full Ford power train all the way through the rear axle. And my EFI plan means all my tech questions can be asked here.
Gigemags05
1947 and Older Ford Trucks
Nov 18, 2014 11:29 PM
cookieman69
Nov 23, 2009 12:02 PM
bbussman40
Apr 13, 2008 11:45 AM
jared66
18
Feb 20, 2007 08:54 PM
wegobush1958
Jun 6, 2002 02:42 PM
