53 Hazard light wiring
Old Jun 2, 2002 | 08:07 PM
wegobush1958's Avatar
wegobush1958
Old Jun 4, 2002 | 12:03 PM
tgregoire's Avatar
tgregoire
Does anyone know how to wire up a four way flasher (hazards) in my 53 f100? I have a newer wiring harness but no provision for flashers.
Old Jun 4, 2002 | 02:46 PM
darkhorse54's Avatar
darkhorse54
If you're using the original column then you need to buy an after market blinker switch because your 53 didn't have emergency flashers.
Old Jun 5, 2002 | 09:20 AM
tgregoire's Avatar
tgregoire
I have a mid 80's GM tilt/telescopic column, so I have the switch on the column. Not sure on the correct wiring.
Old Jun 5, 2002 | 02:17 PM
darkhorse54
Ok then, I have an 82 Pontiac Sunbird tilt column in my 54 f100, you need to buy another flasher with 2 connections and run a full time hot wire to one side then pull your hazard button out and touch a hot wire on your wires coming out of the column until you find the wire that makes all your blinkers light up and hook that wire to the other side of the flasher thats it. I had an extra one that had 3 connections and they work to just use 2 of the connectors.
Old Jun 6, 2002 | 09:24 AM
tgregoire's Avatar
tgregoire
Thanks for the help, I will give it a try.
Old Jun 6, 2002 | 02:42 PM
darkhorse54
Mine was a brown wire, yours might be the same.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
