water pump or head gasket
Ok so I thought I needed a head kit my truck runs and drives great till I run out of coolant no smoke doesn't get hot I run out of coolant I lose my turbo. Pull over fill it up I'm back to normal I just noticed I have sweat marks on my water pump pulley. Need some input here
05 F350 6.0
05 F350 6.0
If a head gasket, open the radiator cap and watch for bubbles in the coolant....the bubbles will be obvious if the head gasket is a severe leak......also, go to a radiator shop and have them pressure test the system.....they can put a pressure gauge on the radiator to check for pressure build up if leak is head gasket
