Burning leaves
Old Nov 17, 2014 | 08:50 AM
Gary Lewis's Avatar
Gary Lewis
My first experience with that was more of a camp fire smell. Thought someone was burning leaves that fall, but when I looked around I discovered that no fires were within a couple of miles. It was the truck - although not quite on fire it was smoldering. Not what I'd call an air freshener.
Old Nov 17, 2014 | 09:29 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yeah
Not so good when the resistor sets the tinder afire and the blower fills the cab with smoke.
The plastic plenum usually doesn't survive either.
Old Nov 17, 2014 | 10:06 AM
Gary Lewis's Avatar
Gary Lewis
I was lucky since I'd read about this problem here on FTE before it happened. So when I smelled smoke I quickly turned the heater off and things cooled down, (the motor cooled down, and that's when I heard the highway sound).
But, I went through a mental checklist as I was doing it that went like this: I could turn the blower to High and bypass the resistors, but if the fire is already started that would fan the flames, literally. Or, I could turn it to Low, but that puts more resistance in the circuit and makes the resistor hotter. Hmmm, I wonder if one of the middle speeds would be best - less heat in the resistor and more air flow to cool the resistor.
In the end I realized that this analysis process was ...... stupid, and the best approach was to turn the blower off as quickly as is possible.
Old Nov 17, 2014 | 01:16 PM
whisler's Avatar
whisler
Nothing like a little Chuck Berry in the morning! We are showing our ages (and mine is more than yours)
Old Nov 17, 2014 | 01:27 PM
Gary Lewis's Avatar
Gary Lewis
Yup - but at this advanced age a year or two makes little difference.
Anyway, you are right about Chuck and his V8 Ford.
Old Nov 18, 2014 | 08:20 PM
parr4's Avatar
parr4
Weather warmed up enough today to work the issue. Removed the blower and saw no leaves. Removed the resistor pak and saw about 4 little leaves with some dust. Felt some packed dust at the front of the evaporator, so I make a 'pick' from a #10cu wire and loosened what I could then vacuumed out the case as best I could. Once the blower was out I could see my 'fix' from long ago was still in place. Nothing but very small bit/pieces could get by it, so where the few leaves were from, might have been from the 1996 evaporator replacement. My fix was installed after that work. Did not take the case apart and did blow out the ducting.
The pinhole cover might arrive tomorrow. I'll need to repaint it but no hurry. Made a cover from ¼" mesh screen, plasticized it and attached it with small black cable ties. Almost invisible even though it's on the outside of the cowl.
Bozworth
58
Sep 22, 2016 04:52 PM
leonharu
Garage & Workshop
18
May 8, 2007 02:18 PM
Fair 96
Paint & Bodywork
Sep 18, 2006 11:33 AM
highboy 74
Aug 28, 2005 11:47 PM
gatorfan
Paint & Bodywork
Sep 23, 2004 09:04 PM
