"GEMMER The Impaler"
Old Nov 12, 2014 | 04:11 PM
1964FORDTUF's Avatar
1964FORDTUF
LOL...Took it out today to start on my scheming for a power steering upgrade I can pass along to the masses....
Old Nov 12, 2014 | 09:52 PM
1972RedNeck's Avatar
1972RedNeck
If you're not using that column and the turn signal switch works and you want to make a little money, PM me.
What are your plans for power steering? I was going to use the Toyota box but decided that I actually liked manual steering.
Old Nov 13, 2014 | 10:38 AM
1964FORDTUF
Im actually working on a Ben Frankin solution, which allows to keep the original box and all other original steering gear and possibly sections of the column. The new F150's and many other new vehicles are abandoning hydraulic power steering so if I can come up with a kit for the slicks, eureka. If not and I go hydraulic, I would likely go down the same path as others have with a Bronco box or other box fwd of the shock tower, pump, pulleys, hoses, etc. A lot more mods to the frame and engine than I am hoping for to go hydraulic, so we'll see. For now Im holding on to the stock column and ain't cutting nothing till all ducks are aligned - Axles / Suspension / Steering after frame blast and paint but I'll for sure let you know first if I let any of these items go.
Old Nov 17, 2014 | 08:28 AM
svolpone's Avatar
svolpone
ah, he beat me to asking you for the column. i just put mine in and it's bent. what a pain in the rear. now i have to figure out what to do next. sorry if i'm hijacking your post. i'm justed pissed about my column. i'll post my own thread and whine like a baby there.
Old Nov 17, 2014 | 10:06 AM
1964FORDTUF
No problem Steve. Im in a holding pattern, had go back out and shake the money tree before the Fat Guy in the red suit gets here...Im really not sure which way Im going with this yet, the guy Im working with is slow to respond, so Ill post again when something "real" happens. Happy Holiday
Old Nov 18, 2014 | 07:16 PM
1972RedNeck
Two wheel drives (and the pesky '66 F100 4X4's) are different.
Old Nov 19, 2014 | 07:26 AM
1964FORDTUF
GOOD CATCH!! --- Steve FYI:
Steering Box: 64 F100/250 4x4 = C3TZ 3504-S
Steering Box :64 F100/250 4x2 = C3TZ 3504-U
64 4x4 Shaft and Worm Assy = C3TZ 3524-R
64 4X2 Shaft and "Rack" Assy = C1TZ 3524-A
Not sure what your column tube needs are, column shift / floor shift? Send a pic of the chopped shaft on the box to my email if you want. Im curious to see just what you have going on there, see if I can help any further.
Old Nov 19, 2014 | 08:07 AM
svolpone's Avatar
svolpone
oh yeah. different for 2wd. i knew that and forgot. so i have two of those steering boxes and no Shaft and Rack Assy. lol. not a good combo. i have some feelers out. patience is required with a 50 year old truck. i have to keep reminding myself of that.
Old Nov 19, 2014 | 11:51 AM
1964FORDTUF
Yeah, understood on the patience part of it. Hey Im still curious to see where your PO cut the shaft and his mod for the rag joint. If I end up doing the Electric Power Steering I will have to cut the shaft and u-joint. I am hoping to find a 2nd complete assembly before I buy the electric kit. Good luck man -
Old Nov 19, 2014 | 12:11 PM
svolpone's Avatar
svolpone
he cut the shaft a few inches (maybe three or four) above where the shaft goes into the gear box. i'll take a picture tonight.
Old Nov 25, 2014 | 09:34 AM
svolpone's Avatar
svolpone
Here are some pictures for you. Btw, what's your name? You should put something in your signature so i don't call you 64 or something.
Old Nov 25, 2014 | 09:48 AM
1964FORDTUF
Thanks Steve. Ill send you a PM, you should have all my info from a Holley 4bbl you sent me, if Im not mistaken. Anyway, its probably a blessing in disguise you took this apart if I am seeing correctly. Looks to me you were steering your truck by not much more than a pin or bolt through the steering shaft the PO cut off. I suggest if you go back together with the same type of set up, and you dont plan on splining the shaft, you should have the bottom half of the rag joint welded to the shaft on the box. Even you pin it and get several good tacks at least you are not relying on the pin alone. Others will likely chime in on this. Catch ya on the PM.
Old Nov 25, 2014 | 10:21 AM
svolpone's Avatar
svolpone
yeah, i guess you're right. not ideal. i'm getting a 67 column from Pat (a guy in Oklahoma) so I'll figure something out when I get it. I'll probably use the other one, spline it and get a new rag joint. seems safer that way.
Old Nov 16, 2015 | 12:24 PM
1972RedNeck
So how is the power steering coming along?
Timothy R. Wyatt
Mar 21, 2017 08:38 PM
wallyworld
Dec 2, 2014 04:34 PM
tardster
13
Jul 2, 2011 12:35 AM
hivolt5.0
23
Jan 15, 2009 07:30 AM
williamwilliam
15
Jul 21, 2003 09:18 PM
