ICP
Old Nov 8, 2014 | 05:52 PM
Powerstoke73's Avatar
Powerstoke73
ICP
I was getting a OBD code 1211 so I unplugged the ICP on the driver side vavle cover and it looked like the oil was blowing all the way threw the sensor what seems to be the problem here this sensor is only a year old
Thanks
Old Nov 8, 2014 | 06:41 PM
Bonanza35's Avatar
Bonanza35
Was it OEM or part store. Don't play with part store sensors when it comes to your 7.3L diesel. If it was OEM I believe it has an 24 month warranty.
Old Nov 8, 2014 | 07:05 PM
Powerstoke73
Yes it is i bought it from the stealership for sure
Old Nov 8, 2014 | 07:17 PM
F350-6's Avatar
F350-6
When you say oil blowing through the sensor, do you mean some oil residue in the connection?
When do you get the P1211 code? Do you have a chip or tuner in your truck? 1211 doesn't usually signify a bad sensor.
Old Nov 8, 2014 | 07:21 PM
Cracker 73's Avatar
Cracker 73
You can run it unplugged it will go to a pre set ecm psi will not run great but will til you get a new one just spray old plug with electric cleaner and blow out residual you will be good to go but use oem
Old Nov 8, 2014 | 08:26 PM
Powerstoke73
Yes i am running a f5 DP tuner but it stays in 80 HP economy mode
Yes it has oil in the connector and in the plastic part of the sensor
Old Nov 8, 2014 | 08:43 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Oil in ICP = new ICP time. You can delay the inevitable by cleaning it, but why?
You bought the leaker at Ford, right? Did you save the receipt? Nah, I wouldn't either. Go buy a new one from Ford, wait a month, return the old one as defective, get refund.
That's not dishonest if you got the leaker there before and it failed while under warranty.
Old Nov 9, 2014 | 07:19 AM
F350-6's Avatar
F350-6
Unless you have a no codes tune from DP, then a P1211 is a very common thing and can be ignored.
Old Nov 9, 2014 | 08:04 AM
Tugly's Avatar
Tugly
Man.... I really didn't want to go here, but I want to help Powerstoke73 (and other drivers with the same problem): The ICP spiking is harsh on the sensor.
Old Nov 9, 2014 | 01:19 PM
jhl3's Avatar
jhl3
I had the 1211 code. Replaced the ICP due to oil in connector and the code is now gone. I also have an ICP that is spiking. Mine is doing it with the 80E tune from DP and the 60tow. I am pretty sure that it was doing it with the old powerchips that was in the truck when I bought it. I am not trying to highjack this thread, just lending a bit of credence to Tugly. I can't imagine it would be good for anything else either to include the injectors. I will try to duplicate it in stock mode. I am also subscribing to your thread so that when I get to the bottom of this problem or at least more info I can share it.
To the original poster: I have read other places that low fuel pressure and or lack of supply can cause this also (ICP spike). Do you have any way to test either. I should have a way to test both later this week. If any of you feel this is bad info, please weigh in..... you may help many of us as well.
aphotic26
6.4L Power Stroke Diesel
18
Aug 30, 2013 05:15 PM
rangerbob406
Jan 19, 2013 08:14 PM
rwdfan
Jan 3, 2012 10:42 PM
SLAMMIN 22
May 23, 2011 07:34 PM
rgvrealtor
Mar 22, 2011 12:08 PM
