ICP I THINK??? WHAT DO U THINK??????
Old May 22, 2011 | 01:06 PM
SLAMMIN 22's Avatar
SLAMMIN 22
TRUCK HAS BEEN ACTING UP LAST WEEK OR SO CODE IS ICP LOW VOLTAGE ACCORDING TO SUPER CHIP READER. UNPLUGGED TS CHIP NO CHANGE IN HOW IT RUNS OIL IN ICP SENSOR CLEANED IT UP STARTED TRUCK WITH IT UNPLUGGED THEN PLUGGED IT BACK IN CODE CAME UP AGAIN WHEN IT ACTS UP IT MAY DIE OR SOUND LIKE IT IS MISSING NEVER HAD A PROBLEM LIKE THIS BEFORE NEED SOME ADVICE BEFORE I HAVE TO TAKE IT TO A SHOP THANKS
Old May 22, 2011 | 01:22 PM
Pocket's Avatar
Pocket
It's going to throw a code when you unplug the ICP sensor. The question is, did it run better when you unplugged?
Old May 22, 2011 | 01:29 PM
SLAMMIN 22's Avatar
SLAMMIN 22
I didnt drive it just started it . should I drive it with it unplugged????????
Old May 22, 2011 | 01:51 PM
Pocket's Avatar
Pocket
Try it and see if it improves.
If it runs better with the ICP sensor unplugged, it means the sensor itself or wiring is bad. If it runs the same, it's not the sensor.
Old May 22, 2011 | 02:02 PM
SLAMMIN 22's Avatar
SLAMMIN 22
ok I will try it it is 30 miles to my shop if I drive it that far is it ok ??
Old May 22, 2011 | 11:21 PM
Pocket's Avatar
Pocket
Yeah, it's fine.
Unplugging the ICP sensor doesn't hurt. The engine will still run and drive. It's just the PCM can't fine tune injection pressure for any given RPM and mass fuel desired, so the pedal might feel jumpy or dead at times. Just pay attention to how the engine runs to see if there's any improvement.
Old May 23, 2011 | 07:34 PM
SLAMMIN 22's Avatar
SLAMMIN 22
New sensor today and all seems good. Put chip back in and NO problems so far drove het about 60 mile THANKS FOR THE HELP!!!!!!!!!!!!!
navistarnut
Oct 19, 2018 01:53 PM
F-250 Super Duty
47
Jun 4, 2014 04:59 PM
chev69ss
Jun 3, 2014 12:04 PM
IceboxFX
16
Mar 18, 2008 07:27 PM
fishmanndotcom
May 3, 2006 12:45 PM
