PO198 oil temperature sensor high code
Old Jan 3, 2012 | 12:32 AM
rwdfan's Avatar
rwdfan
Ok, so I have code PO198 oil temperature sensor high. I have an EDGE CTS scanner/monitor, and it shows my oil temperature readings from the very sensor going haywire, typically I start the truck up in the morning, and its fine. But after a while it heats up to 160-170 degrees, runs and drives fine, oil pressures normal, and then randomly the c.e.l. comes on and the temperature reads as 212 degrees and just stays there for anywhere from 5-10 minutes, then it goes back, reading normal. Starting and stopping the engine has no effect, it will stay on. Does this mean I need a new sensor or if theres something else going on? Also, I cant find a oil temperature sensor online or at the auto parts store...is this thing called something else? Thanks.
Old Jan 3, 2012 | 02:36 PM
rwdfan's Avatar
rwdfan
BUMP! Its still doing it...ideas?
Old Jan 3, 2012 | 08:08 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Jan 3, 2012 | 08:20 PM
riverrat41's Avatar
riverrat41
Not for sure but maybe a faulty Engine Oil Temperature Sensor?
Old Jan 3, 2012 | 08:26 PM
Kajtek1's Avatar
Kajtek1
I had experience with one of the timing oil temperature sensor (EOT on the drawing above !) blowing up and there was no way to avoid the dealer. The engine has a maze of sensors and even mature NAPA technician had no idea when I pointed the sensor on the engine.
Doubt you will find the aftermarket sensor. Bite a bullet and buy the sensor from the dealer. I paid $149 with a discount.
But before doing that, make sure there is no loose, or damaged wire.
Old Jan 3, 2012 | 10:42 PM
rwdfan's Avatar
rwdfan
Yeah, thats the same problem I had...Oreillys and Napa had no clue what I was talking about. I even checked partsguyed.com and rockauto.com and neither have it. I guess I'll have to call the dealer...ugh. I will check the wires though now that riverrat gave us an awesome diagram. Thanks!
friskyjake
Mar 20, 2017 02:21 PM
Powerstoke73
Nov 9, 2014 01:19 PM
jfletcher72
Jun 16, 2014 06:20 PM
Dutch13
6.4L Power Stroke Diesel
Feb 27, 2014 08:18 AM
Farmboypowerstroke
Sep 27, 2010 11:24 AM
