help squealing pulley/belt
Old Nov 7, 2014 | 11:49 PM
Dennis Anderson's Avatar
Dennis Anderson
the front end of the engine squeaks but when I put belt dressing on the belt it will stop squealing for about 5 seconds and tjen starts back., is anyone have experience like this, would this be the drive belt issue or a pulley issue. 1999 ford f250. Thanks
Old Nov 8, 2014 | 03:08 AM
bike_guy123's Avatar
bike_guy123
This is my experience and I hope it helps. Mine started doing that and I tried the same things you are doing with the same results. It wasn't long and belts started shredding. I learned, after about 4 belts, the tensioner/idler unit was the main cause of all my problems. After replacing that, I haven't heard a thing.
In fact, it was that very same problem that brought me to FTE in the first place.....that is where my searching started.
Good luck.
Old Nov 8, 2014 | 09:39 AM
unclebuck48's Avatar
unclebuck48
Try a quality belt, belts from say autozone will cause this, try a good year gator.
Old Nov 8, 2014 | 11:25 AM
F250_'s Avatar
F250_
If you ever get coolant or power steering fluid on the belt, it's going to squall until it's replaced. Those fluids will also cause the belt rubber to soften, and pack into the pulley grooves and must be cleaned out prior to installing a new belt.
Old Nov 8, 2014 | 12:09 PM
Franko72's Avatar
Franko72
Molon Labe
Yep. I had squeeling problems from cheaper belts. A good Gates belt and it's been quiet for two years now.
Goodyear gator is a good belt.
Old Nov 10, 2014 | 09:19 AM
Dennis Anderson
Thanks everyone for good advice. Gonna change O'Reilly bought belt
Old Nov 11, 2014 | 11:53 AM
Cracker 73's Avatar
Cracker 73
Belt dressing is really more for v groove belts and you can clean your belt to stop the noise. Take a small brass bristle brush hold on grooved side of belt at idle this will fix noise and give it a renewed bite. Also they have groove depth checkers from gates.
Old Nov 14, 2014 | 10:26 AM
ToMang07's Avatar
ToMang07
Check the tensioner and pulley.
Dennis Anderson
Dec 17, 2014 04:46 PM
96Dixie
Feb 23, 2007 06:49 AM
GR854
May 11, 2006 04:04 PM
cmoore99
Jan 29, 2005 09:45 PM
zamboniman30
1983 - 2012 Ranger & B-Series
27
May 20, 2003 08:53 PM
