Engine hours vs. miles
Old Jan 12, 2017 | 06:20 PM
  #46
bismic's Avatar
bismic
Originally Posted by dlynes
So the slower your average speed is, the more wear and tear it is thought to have on the motor vs higher the speed? ie....29 mph vs 55?
What is an average mpg for a truck with over 200k miles?
To add to the above posts - idle time can contribute to slightly higher amounts of fuel in the oil (there is always a potential for small amounts of this even in healthy engines). If you idle a lot after first start, I believe it can generate soot. Not a huge deal, but it can affect things over time. These engines like to operate at the design temperatures (oil, coolant, transmission fluid, etc)!
Old Jan 13, 2017 | 12:59 AM
  #47
87crewdually's Avatar
87crewdually
Here's the other info I mentioned earlier.
Old Jan 13, 2017 | 07:52 AM
  #48
TooManyToys.'s Avatar
TooManyToys.
Yeah, that kind of nails the issue.
Emergency service vehicles fall into this category by nature. As do utility vehicles with lifts that don't use a pony motor for equipment power. At idle and at hot temps, the low pressure oil system is also at a rather weak level compared to most engines. I would expect Nav designed around that but by nature it gives me pause.
Old Jan 13, 2017 | 12:42 PM
  #49
Euroman's Avatar
Euroman
Originally Posted by 87crewdually
A high hour/ low mile passenger vehicle engine indicates extensive idle time. Idle time is a cold engine bringing on wet stacking and oil dilution with fuel. Diluted oil gives you increased wear. It's said one hour of idle is equalivent to 25 miles of wear.
Ford recognized this and put out an announcement. See first bullet. There was another announcement about extensive idling but I'll have to search for it.
Not good - the whole of Europe runs on B7, which is more than Ford recommends. In 2020 it will probably go higher.
On the other hand 100k miles in 2500hrs is not too bad...
Old Jan 13, 2017 | 08:25 PM
  #50
r2millers's Avatar
r2millers
Thanks 87.
Good reading, appreciate both postings.
Tried to rep but more spreading first.
pbssouthland
6.2L V8
Nov 10, 2017 06:42 PM
Monster-4
6.7L Power Stroke Diesel
13
Jul 27, 2017 08:47 AM
SANDDEMON08
6.4L Power Stroke Diesel
Jul 3, 2014 08:49 AM
TAT2DUP81
Dec 11, 2010 08:11 PM
The Gambler
15
Jan 8, 2009 07:33 AM
