GT40 Heads
Old Oct 21, 2014 | 11:10 AM
Gigemags05's Avatar
Gigemags05
GT40 Heads
I am in the process of tearing apart and going through an 82 351w.
I am going to put in a new cam, new intake, new carb, and new exhaust.
How much benefit would I get from swapping the factory heads out with some gt40 heads?
I don't have the need or the $$ to swap in aluminum heads, I don't need a race truck. I just want to have a little more power. Are they a straight swap?
If I can find the heads for pretty cheap would it be a noticeable gain?
Old Oct 21, 2014 | 03:17 PM
Plowboy34's Avatar
Plowboy34
Yes the GT40 heads will be a upgrade of about 25-30 horsepower on there own. As far as bolt on that depends if they came out on a 351 or a 302. If they came out on a 302 you will have to get the head bolt holes drilled out to 1/2", other than that they are bolt on
Old Oct 21, 2014 | 05:43 PM
Gigemags05's Avatar
Gigemags05
Ok thanks for the info.
Old Oct 22, 2014 | 07:34 AM
bruno2's Avatar
bruno2
You need to know how big the combustion chambers are. You don't want the compression ratio to get up over 9.5:-1 if you are running pump gas.
Old Oct 22, 2014 | 10:08 AM
Gigemags05's Avatar
Gigemags05
hmm,
I haven't heard of anyone having issues with that. Is it something I should be worried about with a stock 351w block?
Old Oct 22, 2014 | 10:33 AM
Plowboy34's Avatar
Plowboy34
You will be OK....heads would have to be severely decked or flat top pistons to get above that. If your block is basically stock you should be fine
Old Oct 22, 2014 | 08:09 PM
GLR's Avatar
GLR
Some of the guys on the Crown Victoria, Grand Marquis, Marauder, and Towncar site are also using E7TZ heads. The GTs are more effective.
Old Oct 23, 2014 | 12:29 PM
Conanski's Avatar
Conanski
The '82 351 if all stock is a low compression smog motor.. about 8.3:1, GT40s will bring that up to about 8.8-9:1 depending what version you get, some had 64cc chambers some had 60cc. These things also flow 25% better than stock so along with a cam and exhaust(the other two big factory original restrictions) you could easily be bolting on 100hp.
Old Oct 23, 2014 | 12:58 PM
Gigemags05's Avatar
Gigemags05
Okay that sounds awesome.
Standard Fel Pro gaskets alright?
Also, I am using a C6 with stock torque converter... is that sufficient? Or do I really need to upgrade the TC as well? I would really rather not as this project is getting pretty expensive, haha.
Old Oct 23, 2014 | 01:00 PM
MisterCMK's Avatar
MisterCMK
Ish, E7 heads are good for nothing more than winter weight and keeping your boat from floating away
Old Oct 23, 2014 | 10:08 PM
bruno2's Avatar
bruno2
The cam companies have TC calculators on their websites. When you go with so much cam the TC needs to be upgraded. I didn't change mine and you can really tell the tranny is fighting the motor.
Old Oct 24, 2014 | 07:42 AM
bruno2's Avatar
bruno2
I am not very familiar with the GT40's. I know they were on some 302 motors and wanted the OP to be aware of the CR factor.
Old Dec 7, 2014 | 12:54 AM
Four.on.the.floor's Avatar
Four.on.the.floor
Would you just leave the rocker arms alone if you were to take them off a 1996 explorer that has gt-40s so literally take them off and just bolt on and go. ?
ovalhead72
Sep 12, 2018 09:53 PM
73BlackBeauty
Feb 26, 2009 08:17 PM
TheNomad
Jul 9, 2008 08:27 PM
bodyman
Feb 1, 2004 12:53 PM
Titus Smith
Nov 20, 1999 11:55 PM
