302 Head swap
Old Feb 25, 2009 | 11:01 PM
73BlackBeauty's Avatar
73BlackBeauty
302 Head swap
I have a 1976 302 i was wondering if any heads will bolt on to this or if not which ones will i was hoping that e7te or gt 40 heads will. Any input is appreciated.
Old Feb 26, 2009 | 01:03 AM
Beanscoot's Avatar
Beanscoot
Any small block heads will bolt on. 351 heads will need to use special bolts or hardened washers.
Old Feb 26, 2009 | 07:45 PM
1966Tbird's Avatar
1966Tbird
or put a sleve in the bolt hole because 351 heads used bigger bolts than 302 heads a set of DO0E heads will flow similar to GT40s and be a lot cheaper the e7te heads are crap in my opinion, it's what i have and i had to port the hell out of them just to get them to flow decently, definatly would not do that again
Old Feb 26, 2009 | 08:17 PM
fordeverpower's Avatar
fordeverpower
i wouldn't use e7te heads on anything, they plain suck. The 76 302 may still have the early heads on them. I am not real sure, the d8oe heads also suck and have a bigger combustion chamber resulting in less compression.
