Long start facing down hill
Old Oct 19, 2014 | 05:19 AM
Iaff113's Avatar
Iaff113
It's off I need to thank everyone who had helped me lately with my 150000 wear out adventure in replacing a bunch of stuff I would be paying a lot more if it wasn't for this site and it's people. Ok so when I face the truck down hill it take a bit more time to crank then when it's level and facing up hill I will post videos of both as you will see in the video it takes the icp a lot longer to build. I have seen plenty of threads about oil leak by when facing up hill but not much about facing down. Here are the videos The first video is a normal start the second is facing down hill both are after cold soaks and no smoke after start up http://s1336.photobucket.com/user/ia...bile%20Uploads
Old Oct 19, 2014 | 08:04 AM
lostru's Avatar
lostru
Dummy Plugs good?
Old Oct 19, 2014 | 09:10 AM
Iaff113's Avatar
Iaff113
Not to question you but is it the dumb plugs and stand pipes that give hot no start issues? I'm not sure on the plugs.
Old Oct 19, 2014 | 09:15 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Bad dummy plugs can give long cold starts as well.
One way to check is first thing in the morning is to pull the ICP sensor, the oil level should be near the threads, if not it's bleeding down and most likely the dummy plug on the passsenger side.
If it passes that test it's more than likely the driver's side DP.
Josh
Old Oct 19, 2014 | 09:37 AM
lostru's Avatar
lostru
Oil will leak out past the dummy plug O rings as it sits weather hot or cold. Our HPOP takes a few seconds to refill the rails. I just replaced mine since I was there doing the STC and EGR. Passenger side was good so oil was up to the threads at the ICP. I pulled the driver side and the lower O ring was distorted and almost cut in half. From what I read its very seldom the stand pipes that fail but your there already. My starts had been a little slow but I hadn't troubleshot it. Just figured it was the STC.
Old Oct 19, 2014 | 09:39 AM
Iaff113's Avatar
Iaff113
Ok we'll I will check this tmrw after a cold soak on the hill and let you know. Thanks for the info
Icicle
25
Jun 8, 2014 10:01 AM
PSDlongbox
Sep 15, 2012 02:09 AM
f350ranchand
Jan 30, 2012 09:51 PM
61 uni
Dec 22, 2009 05:06 PM
rocknrone
Sep 12, 2007 07:29 PM
