Australia Chapter Join Chapter , Leader: OPEN
EZY-LIFT
Old Oct 17, 2014 | 09:04 PM
Blue7.3's Avatar
Blue7.3
EZY-LIFT
Here's a gas strut that i fitted to the tail gate , this slows the gate down when you open it , you just let it go and it slowly opens , without smashing down and stressing the wire straps.
It's a shame they didn't invent something to make it easier to lift closed.
There are a heavy tail gate , this just make it a little easier , you only have to release the tail gate handle and it goes down by it self.
ezy-lift strut , no holes to drill ,just fits in the existing holes.
Old Oct 17, 2014 | 09:43 PM
Aussie BrianB's Avatar
Aussie BrianB
Blue,
I fitted and Easy Lift
Best $30 I ever spent on a vehicle.
The installation is a no-brainer and it works as claimed.
I can lift my tailgate with one finger and it drops down quite
slowly and gently.
Even the missus likes it!
LMC carry them, probably other dealers as well.
Old Oct 17, 2014 | 09:59 PM
Blue7.3's Avatar
Blue7.3
Yeah there good value , i think Ford should have fitted them from new !
Old Oct 18, 2014 | 04:59 AM
SSSimon's Avatar
SSSimon
I got mine from RR - I think it was called the EZ-down.
I see you ground off the tailgate locating rubber to accommodate the device.
That was a good idea. The instructions said just remove it if it fouled the shaft. But grinding the rubber down still allows the rubber to centre the tailgate.
Now I know what my next F250 job is - locate, grind, and re-fit this rubber!
Old Oct 18, 2014 | 05:06 AM
Patchy 73's Avatar
Patchy 73
What a top idea
Can you give me what size strut you are using
Cheers,
Patchy
Old Oct 18, 2014 | 03:52 PM
Blue7.3's Avatar
Blue7.3
I will measure it up for you this morning, they are set at a stock length for your tail gate.
Old Oct 18, 2014 | 04:42 PM
Blue7.3's Avatar
Blue7.3
Okay here's some measurements.
Overall length= 300mm
Body= 185mm
shaft= 120mm to the nuckle
Shaft= 8mm O/D
Body= 18mm O/D
It would be quite easy to make your own , but for the price of them i didn't think it was worth the trouble.
Hope this helps.
Old Oct 18, 2014 | 05:44 PM
Patchy 73's Avatar
Patchy 73
Thanks for that,
Cheers,
Patchy
Old Oct 19, 2014 | 02:42 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
The new F150 has a torsion bar built into the tailgate to help assist lifting it
The gas strut idea is good. Is it easy to take on/off when removing the tail gate?
Old Oct 19, 2014 | 03:18 PM
arctic y block's Avatar
arctic y block
Would this system work on my Bronco?
It has the factory torsion bar but is still
a sunny beach to lift.
Old Oct 19, 2014 | 03:58 PM
Blue7.3's Avatar
Blue7.3
I can't see why it wouldn't work on any vehicle wit a down loading tail gate, the main thing is to get the pivot point correct and the length to the strut .
If you look on the Ezy-lift site they may even make them for your model.
Dee Zee Tailgate Assist Kits
Old Oct 19, 2014 | 04:48 PM
arctic y block
Thanks Blue. The Summit site only lists back to
'97 and nothing for a Bronk. I will do a little more
looking around. Than prolly have to call anyway.
I hate menus an off shore accents. Being deaf may
have a lot to do with that.
4x4pwr
Apr 9, 2023 04:31 PM
senix
2009 - 2014 F150
Apr 18, 2017 07:10 PM
X36
Dec 19, 2008 08:27 PM
SpankF100
Apr 15, 2005 09:29 PM
