Clunky steering
Old Oct 17, 2014 | 05:03 AM
baileyj's Avatar
baileyj
Clunky steering
My son has a 2007 Ford Truck F150 1/2 ton P/U 4WD 5.4L , when he turns the steering wheel left and right you can hear a clunky sound on the rack and pinion right where the steering shaft connects. Any ideas?
Old Oct 17, 2014 | 05:22 AM
David7.3's Avatar
David7.3
Replace the steering shaft, there might be a TSB on it, check it out, if you spray lube the shaft and the u-joints on the shaft and the noise goes away you got it.
Old Oct 19, 2014 | 08:24 AM
matt167's Avatar
matt167
ditto.. U joints in my truck were pretty tight, so the steering had 4 clunky 'notches'.. I've managed to avoid the $250 steering shaft replace by using chain lube on the u joints periodically ( every time I check fluids ) and it keeps them free
0351mike
1978 - 1996 Big Bronco
Dec 3, 2017 04:47 PM
yasky69
Modular V10 (6.8l)
Aug 22, 2010 11:35 AM
cadriver
1983 - 2012 Ranger & B-Series
Jun 9, 2007 08:39 PM
Avanti
Bronco II
Apr 4, 2005 10:20 PM
fishin1976
Jun 24, 2003 10:19 PM
