P0172, P0300, P0303 codes.
Good evening folks. I'm normally in the 6.0L section.
My son just left. We scanned his truck and got these codes.
P0172 Bank 1 rich
P0300 random misfires
P0303 cylinder 3 misifres.
I used the Torque APP Pro to check these codes. I went to live readings in the Torque APP and saw some readings for Long term and Short term bank 1 Readings.
They are all "greek" to me, and I don't recall what they were, but could get those readings tomorrow.
When I have done searches combining these codes together, I see changing spark plugs. P0172 alone gets me a different train of thought. Mainly CAT issues.
Oh, also, his cranking to start is quite long. (A lot longer than my 6.0L would ever think of cranking) At least nearly 30 seconds of cranking.
Any thoughts?
We are leaning toward first just changing #3 plug.
P0172 Bank 1 rich
Any thoughts?
I didn't say it was a 5.4l 3v motor. He bought it used. Hasn't gotten an Oasis report on it. So, not sure if anything of any sort has been done to it. He hasn't since he bought it 3 years ago.
110,000 miles on it. Gets only 12 MPG with mixed city/highway.
I have asked a couple times the model year. He says 09.
The son has decided to change out that #3 plug. I suggested moving the coil over to another spot and seeing if the problem follows the coil.
12MPG seems a little low, although you said "son"... so perhaps he has a lead foot. My 09 SCrew 5.4 4x2 3.73LS runs around 13.5-14.5 depending on how kind I am to it - but it has 155K on the clock, aftermarket bumpers, a commercial topper, and about 1K lbs. of equipment on board. It's also used for emergency response, which isn't kind to fuel mileage.
Hopefully the plug resolves it, but that doesn't really explain the rich and random misfire codes. Let us know how it turns out.
As far as lead foot, he is a pretty mild driver.
He pulled the #3 plug. Put in a new one, but it still is misfiring. So, he might move the coil or just throw on another one. Hate seeing him throw parts. But, it seems to take sometime to throw a CEL with this misfire.
He drove 30 miles from my place to his without a CEL being set. Do these motors have "soft codes" like my 6.0L does?
Here is a pic of the removed plug.
Thanks.
Thanks.
Update
So, he decided to go ahead and replace all the plugs on bank 1.
Pulled #4, went well,
Pulled the #3 again just to see what it looked after driving some, plug was as black as the original #3.
Pulled #2, it looked better than the new #3.
Pulled #1. Well, that didn't go well. It broke. So, he will be getting the tool to remove the rest of the plug.
Has there been an issue where the last part of the plug falls into the cylinder?
Here is the picture of the plug.
We are leaning to an injector issue.
crazyodaz77
05-19-2019 09:33 PM
madMatador78
17
01-16-2016 07:40 PM
Hurlmetal
09-20-2012 11:18 AM
