I went with the regular lifters. Barry talked me out of it, said you give up adjustment and $100 and get nothing useful in return - meaning it will spin up to 6,000, and anything above that is useless in a street ride.
Now, if it were a race build it would be different. You probably know, since you have one, the old 4WD trucks are not precision instruments. You point them and pray. I'm looking for 0 to 75 mph, because after that it is just a little too scary.
He is out of heads, so it will be a bit of a wait, but I hope I can get the bottom end in so we can get the block machined and the pistons fitted.
Your motor def going to be a little more racey than mine. I'm basicaly trying to accomplish the same thing you are. Did he say wether he had the flat top stuff I stock or not? Back when I waited forever for dished he made it sound like that was the only kind that took forever to get.
That's awesome! Now in 6 months when you get your parts you can start building too! I shouldn't say that I hope you get your stuff a little sooner.
Barry recommended the Quickfuel 780 for mine. He said it's more bang for the buck basically over the Holley. I haven't gotten much of a chance to look at them yet.
I bought the 780 QF for my 418.
When I bought the parts from Barry for another engine & he gave me a time line I told him if he could not have them by a certain date I was not interested.
It took much longer than date told but I had to keep the pressure on to get them.
Current build I wanted to use his heads but getting them in a timely manner was a issue I did not want to deal with. Bought the BBM's and had them in a week.
I have heard 6 months to a year for a engine once ordered . . I could never handle the stress. Just parts could be much sooner.
What do you think about the 780 you bought? Do you think it's much different or better than the traditional Holley?
I'm trying to reach him to ask a few questions. One concern I have is he suggested a 33-000-9F cam, which is what you posted. He told me it would have durations of 234 and 240 at 0.050 inches of lift, and lift of 594 and 598. After ordering it I came back to this thread and you had posted the label that came with your cam, which was a 33-000-9 and it was a smaller cam. You mentioned a mix up, but I'm not sure if it was CompCams on the grind or Barry's on what he said it was. I'd like to make sure I know what the spec is. I also forgot to specify that I need a gear for it for a stock distributor.
Hmm I'm not sure there. My cam is def smaller than that. I wonder if the F has anything to do with it. I think the lift is only .556 both sides on mine.
I got tired of trying Barry, so I called Comp. The guy there said that 33-000-9F is the number for ALL Ford FE custom grinds, so it imparts NO information about the cam profile. This explains why you and I have the same number for two different cams.
I am still asking Barry for the specifics on the cam he is ordering for me because the order doesn't specify it.
I also need to get the right gear for a stock FE distributor.
That makes more sense I guess on the part number. As for the distributor gear I still need one too. I wasn't too wild about the brass gear. If you find a steel gear let me know which one you get.
From what I read the brass doesn't last very long either. I forget who makes it but someone makes a steel gear that guys have been running with these billet cams.
Hi, I think I can help on these two items. The actual lobe number is on the cam card, I think it showed 3308R/3309R? those are Comps lobe numbers. You can look up the lobe numbers on Comps website, it will list all the specs for them.
You want to use a STEEL distributor gear, the bronze ones wear too fast for street use. Comp, Crane, MSD, and Mallory are the ones I have heard of, or Comp has a composite gear that would work also. You need to make sure to get the correct ID gear for your distributor.
