P1249 Code
Old Oct 12, 2014 | 10:42 PM
Steelheader87's Avatar
Steelheader87
P1249 Code
Just got back from about 700 miles pulling 10,000 lb trailer and got P1249 code. I have searched and sounds like this code is not an issue, just want to confirm. I have the red line disconnected from waste gate, should I reconnect or leave it. I have Gearhead tunning, do I need a boost fooler or just not worry about the code? Thanks for your input.
Old Oct 12, 2014 | 11:06 PM
whitetmw's Avatar
whitetmw
A lot of folks are going to say leave it. I would re connect it and adjust the Wastegate myself.
Old Oct 12, 2014 | 11:49 PM
Steelheader87
If I plug the red line back in and adjust the waste gate, will the code go away? Is there a disadvantage with having the red line disconnected? As always, I appreciate the feedback.
Old Oct 13, 2014 | 06:57 AM
whitetmw's Avatar
whitetmw
Running the vehicle in it's designed configuration is always best to prevent a failure of a component or engine.
Reattach the red line, clear codes and test drive vehicle.
Do you have a Boost Gauge? and, What MOD's if any do you have?
Old Oct 13, 2014 | 11:03 AM
Steelheader87
In terms of mods, 4" turbo back exhaust, Air Raid intake, Gearhead tuning, 6.0 cooler, Insight for gauges. When I got the code, had just finished a long trip and had some hard pulls, but no issues. I did notice some surge, so will be getting a new wheel. Boost got into the mid 20's.
RigCity
Mar 10, 2017 11:27 AM
sweatthawg913
2015 - 2020 F150
Oct 28, 2016 08:04 PM
twg1966
18
Jun 5, 2013 11:22 AM
SBChero
Jun 6, 2007 04:23 PM
DSun
Apr 21, 2006 10:19 PM
