Reverse light wire color?
Old Oct 11, 2014 | 08:54 AM
jonrjen's Avatar
jonrjen
I am wanting to hook something up to the reverse/back up lights on my truck. I know it is the center connection on the 7 wire plug, but want to tap into it further up stream of the wrapped harness.
Does anyone know what color wire this would be?
I am hooking up the reverse light LED bar and a back up alarm FWIW.
Doing a Google search is shows a few different colors, so I'm looking for some real knowledge from you.
Old Oct 11, 2014 | 09:54 AM
jonrjen's Avatar
jonrjen
FWIW: purple with a green stripe.
Old Oct 11, 2014 | 10:28 AM
BlackNM6.0's Avatar
BlackNM6.0
Pull one of the tail lights out and see what color the wires are going to the reverse light.
Old Oct 11, 2014 | 11:19 AM
jonrjen's Avatar
jonrjen
I would have, but I installed tail light guards which were kind of a pain and really didn't want to have to remove them and then install them again.
So I grabbed a test light and crawled under the truck, hit it lucky with the first wire probe.
So now when I put it in reverse I have my OEM back up lights, a LED light bar, a small light that is attached to the reverse beeper and sound.
I also have reverse lights on my headache rack, but I wired those up to one of the upfitter switches so that the lights could be used whenever I needed light in the bed of my truck for things such as hitching up the 5th wheel, reaching for tools in the tool box in the dark.
Old Feb 7, 2021 | 10:55 AM
Kyle Berner's Avatar
Kyle Berner
Answer?!?
so what’s the answer? What color was the wire? I’m trying to figure this same issue out.
Old Feb 8, 2021 | 02:24 PM
ngng's Avatar
ngng
grab a test light or multi meter. when I did my stereo the wire colors were different from everything I had read
Old Feb 8, 2021 | 09:42 PM
Tejasguy2017's Avatar
Tejasguy2017
Should be the purple-ish wire with the orange stripe. My 17 and new 21 has the same ones. Should be in the middle of the plug, use the test light to make sure. I used them to install the bumper with reverse lights.
Old Sep 1, 2024 | 08:16 PM
Citydogkc's Avatar
Citydogkc
2nd Gear
Where is that plug?
I’m putting new mirrors on my 03 F250 and they have back up lights (courtesy lights). Where is the plug in that photo? Is it directly off of the steering column? Thanks in advance.
2wd, 5.4l extended cab.
Old Sep 2, 2024 | 01:32 PM
speakerfritz's Avatar
speakerfritz
1,Blue,Frame Ground
2,Not Used
3,Green,Park/Stop/Turn Lamp 1, Left Rear (without LED)
4,Not Used
5,Gray Orange,Module Communicaton Network Rear Lamp Assembly LH and RH
6,Green Yellow,Rear Turn Lamp Left
7,Green Brown,Rear Lamp Assembly LH and Rear Lamp Assembly RH
8,Brown,RH & LH Rear Lamp Assembly (BLIS Vpwr,Hot in Start or Run)
9,Not Used
11,Blue Brown, Ground
14,Blue Red,Rear Lamp Assembly RH (with LED, with BLIS)
15
16,Green Orange,Rear Turn Lamp Assembly, RH (with LED, with BLIS)
17,Blue Gray,Rear Lamp Assembly LH (with LED, with BLIS)
18,Violet White,Rear Marker Lamp Assembly (Dually marker light)
19,Not Used
20,Not Used
Old Sep 3, 2024 | 01:04 PM
Citydogkc's Avatar
Citydogkc
2nd Gear
Found.
Thank you. I was needing to get in at the steering column and ended up having to remove the fuse box to get access to the connectors. After some probing I found that my backup light wire was black w/ a pink stripe. It seems if you ask ten people you get tend different answers and I’m guessing that due to production variables of the vehicle. It was the same color back at the backup lights themselves fortunately. A side note. I pulled and cleaned the connectors under the dash with crc electronic cleaner and it solved a digital glitch in my odometer. You’ll want to make sure to re-administer some dielectric grease to the pins when going back together.
Looking at the fuses this connector is at the bottom right of the distribution bow under the drivers kick panel.
pspc271
Jun 29, 2018 02:44 PM
Lonewolftx
Oct 22, 2015 04:28 PM
01redcrew
2004 - 2008 F150
24
Feb 5, 2008 03:20 PM
jdadamsjr
Jan 29, 2008 08:19 PM
bigcntry88
Modular V10 (6.8l)
Jan 3, 2003 01:02 PM
