added extra reverse lights ???
Old Feb 4, 2008 | 04:32 PM
01redcrew's Avatar
01redcrew
im trying to add extra reverse lights to my truck and was wondering if on the trailer wires if there was a wire i could connect to and if so what color is that wire.
thanks for any help
Old Feb 4, 2008 | 05:23 PM
ech0sh4y's Avatar
ech0sh4y
there isn't going to be a reverse light in the trailor wireing harnes... at least no trailors I've seen have back up lights ;-) Your best bet woule be to pop out a trail light on the truck and follow the reverse wire down and splice into that puppy. Depending on how many lights you are running you may want to use a relay. Hope this helps.
Old Feb 4, 2008 | 05:54 PM
silver05fx4's Avatar
silver05fx4
hey i seen that Reese makes a light that plugs into your round plug in the bumper ..i seen it lowe's for like 25 bucks ... and i have tested my round trailer light plug and their is a spot for reverse ... i just never made it back out to buy it from lowe's
Old Feb 4, 2008 | 05:58 PM
01redcrew's Avatar
01redcrew
well on my f250 i added extra reverse to it and someone told me on here that there was a wire in the round connection and i found it on my f250. But i dont remember what color the wire was. So i was wondering if the f150 was the same
Old Feb 4, 2008 | 06:03 PM
ech0sh4y's Avatar
ech0sh4y
well I apologize I did not know! Shows how much help i can be =P
Old Feb 4, 2008 | 06:04 PM
01redcrew's Avatar
01redcrew
hey not a problem atleast you tired
Old Feb 4, 2008 | 06:17 PM
silver05fx4
who says anyone is right ford changes stuff daily
Old Feb 4, 2008 | 06:57 PM
moonlighter's Avatar
moonlighter
In the large trailer connector, the center terminal is the auxiliary terminal, if you want to use it. Or you can connect onto wires going to backup lamps.
Old Feb 4, 2008 | 07:14 PM
01redcrew's Avatar
01redcrew
the auxiliary? Does that mean i still have to run a switch for the lights?
Old Feb 4, 2008 | 08:41 PM
moonlighter
If i remember right, the aux. terminal has 12 volts on it. It would be easier for me to hook into backup light wiring.
Old Feb 4, 2008 | 08:48 PM
01redcrew's Avatar
01redcrew
ya i did that on my f250 and it acted light it was to much light and wouldnt light up as much. So thats how i found out about the reverse wire in the round trailer connection so i tied into that and it got alot brighter that way. I also want my lights to come on when i put it in reverse to not by switch if possible.
Old Feb 4, 2008 | 09:10 PM
moonlighter
Put truck in reverse turn key on, be sure backup lights are on, then on trailer connector take a test light and see if you have 12 volts on a terminal, if so take out of reverse and see if the voltage goes off.
Old Feb 4, 2008 | 09:14 PM
01redcrew's Avatar
01redcrew
you said the 12v was the middle wire? Do you remember what color it was
Old Feb 4, 2008 | 09:16 PM
moonlighter
I think it is red.
Old Feb 4, 2008 | 09:17 PM
01redcrew's Avatar
01redcrew
ok thanks alot ill try and get to that tomorrow if it isnt raining all day here
