Reverse light wiring
Old Jun 29, 2018 | 01:38 PM
pspc271's Avatar
pspc271
I've installed a pair of rear led pod to supplement the factory reverse lights. I want to tie them into the left reverse light so they turn on automatically. Anyone know which wire on the 2018 F350 is supply power for the left reverse light?
thanks!
Old Jun 29, 2018 | 02:41 PM
nuctrooper's Avatar
nuctrooper
I'm sure someone will chime in with wiring diagram wire color, but there is a better option. The trailer connection backup light connector is near the hitch frame on the drivers side of the spare tire. If you have the 5th wheel prep kit from the factory, it has the in-bed plug tied to it. if you don't have the 5th wheel prep, the connector is just sitting there with dummy plugs installed. Take a test light and find the reverse power to the trailer connection and splice in right there. That way, there is no risk to your built in reverse lights (should a failure occur in the pod lights) - you have two separate power supplies to your backup lights (and it's easy to get to).
Old Jun 29, 2018 | 02:44 PM
jbrnigan's Avatar
jbrnigan
Reverse wire is located in the "six" wire connector
jonrjen
6.7L Power Stroke Diesel
Sep 3, 2024 01:04 PM
aramirez
Jan 5, 2016 09:48 AM
F350-6
17
Jun 28, 2015 09:18 AM
78pace
Jan 17, 2011 02:59 PM
01redcrew
2004 - 2008 F150
24
Feb 5, 2008 03:20 PM
