ABS light coming on
Old Oct 9, 2014 | 07:39 PM
bigdaddyII's Avatar
bigdaddyII
ABS light coming on
This is in reference to my brothers 2008 STX. Recently his ABS light has been coming on intermittently. There is no rhyme or reason to it, it will randomly come on and stay on for a bit, then just go off. It does t coincide with using the brakes, hitting bumps, etc. I'm not familiar at all with how the ABS systems work on these trucks. I know on Dodge trucks if that happened it likely meant a front wheel bearing was on its way out. Any thought or experiences with this? I tried search but am on my phone and can't search individual forums from the mobile site.
Old Oct 10, 2014 | 07:02 AM
steve(ill)'s Avatar
steve(ill)
on my 2002 explorer it ment the rear axles sensor in the pumpkin was getting weak. Replaced it and problem gone.
Old Oct 10, 2014 | 03:08 PM
1saxman's Avatar
1saxman
Just for grins separate the ABS harness connectors at each wheel and look for looseness or corrosion. I probably would put some dielectric grease in the connectors and try again to see if its okay.
Old Oct 10, 2014 | 03:40 PM
bigdaddyII's Avatar
bigdaddyII
That's worth a try. Both rotors (2wd so comes with bearing hub assembly) was replaced about a year ago.
Old Oct 11, 2014 | 03:01 PM
tjcprop's Avatar
tjcprop
Do you have an aftermarket programmer on the truck or larger tires? My Edge Evolution and larger tires caused my ABS to come and stay on.
Old Oct 12, 2014 | 08:38 AM
bigdaddyII's Avatar
bigdaddyII
It went from 255s to 285s. That was done right after all the brake pads and rotors were changed. Same 17" wheels though. No programmer. Also, truck is a 4.2 liter with around 45,000 miles on it if that matters.
Brenda Lamka
28
Apr 6, 2014 10:39 PM
rjmay
Apr 25, 2010 11:53 PM
nlemerise
Aug 30, 2007 12:58 PM
GALAZIO
Apr 24, 2007 08:38 PM
edub32
53
Feb 5, 2006 09:05 AM
