Compression Question 300K mile engine
Old Oct 7, 2014 | 08:06 PM
AllaboutMPG's Avatar
AllaboutMPG
The Mantra here at FTE is "get the truck operating at 100% before adding power, chips, etc"
I'm looking at injectors and tunes but had a couple of things I wanted to do before pulling the trigger.
Did a compression check today and all cylinders were from 350 to 380. Is that what you guys would expect from a 300k engine?
If you guys say say those numbers are ok the last thing will be an oil analysis. I know, I know, Should have already been doing this but just haven't gotten around to it.
Thanks,
Old Oct 7, 2014 | 10:54 PM
HKusp's Avatar
HKusp
For a three hundred thousand mile engine, yes, those are respectable numbers.
Old Oct 8, 2014 | 08:01 AM
Tugly's Avatar
Tugly
Stinky's at 365-380 PSI (dead cold) with 290K miles.
Old Oct 8, 2014 | 10:15 AM
cjgray1974's Avatar
cjgray1974
That's right where mine are. 375 with one at 400. 334,xxx.
Old Oct 8, 2014 | 03:25 PM
AllaboutMPG
Looks like I'm in good company then. On to the next step.
thanks gang.
SKaero
Aerostar
Aug 16, 2016 11:59 AM
damac
Mar 9, 2010 04:05 AM
ndfollmer
Mar 16, 2009 06:15 PM
raymechanic
18
Aug 27, 2005 06:12 AM
Bhanna4d
Oct 24, 2003 01:32 AM
