compression
Old Jul 26, 2005 | 04:31 PM
raymechanic's Avatar
raymechanic
compression
thank all of you all that help with the timing problem on my MONSTER now the question is what is exceptable compression ratios on a 1967 330md and thanks again for all the help
Old Jul 27, 2005 | 09:52 AM
Mike G's Avatar
Mike G
Welcome aboard!
Acceptable is a steady reading across all cylinders, within a limit of 10% from one to the other. Now I recall 110 psi as being a "good" number to work with.
--Mike
Old Jul 27, 2005 | 12:08 PM
qman's Avatar
qman
I asked this same question a year ago for my 72 360. My numbers ranged from 111 to 118. I never got an answer. The responses were things like they should be close to one another and so forth. But nobody seems to know what actual compression values should be.
Old Jul 27, 2005 | 11:42 PM
rebocardo's Avatar
rebocardo
From what I can gather, 90-100 psi is okay for a used engine as long as all the cyl. are within 10% of each other.
Old Jul 28, 2005 | 12:16 AM
1975Ford's Avatar
1975Ford
Originally Posted by Mike G
Welcome aboard!
--Mike
I also agree.
If the spark plugs look good and no blue smoke from the exhaust. Then cylinders are good.
Old Jul 28, 2005 | 06:29 AM
jowilker's Avatar
jowilker
111-118 wow, never heard of one that close before.
That is the answer that I get, the amount is not as critical as eveness.
John
Old Jul 28, 2005 | 12:40 PM
qman's Avatar
qman
There has to be a range the numbers have to be in. I don't think the engine would be looked at as a strong engine if all the cylinders were 60 psi. In this case they would all be pretty even but I would think they would be too low. Am I right?
I looked over my numbers again, they ranged from 108 to 120. I had one cylinder at 108 and another at 120 and all the others were in the 111-118 range. This is in a 72 360.
Old Jul 28, 2005 | 12:47 PM
jor's Avatar
jor
Here's a quote from Steve Christ's FE book:
" The range of pressures should be 100-250 psi. They should definitely be above 100 psi, but there can be a large difference between engines. An older 352 in excellent condition will show about 180 psi per cylinder. With 75% considered acceptable, the lowest reading of any other cylinder should be 135 psi. An engine with this wide range of readings is not in excellent condition."
jor
Old Jul 28, 2005 | 11:34 PM
Cracker289's Avatar
Cracker289
It depends on a lot, especially the cam. A high performance cam with more valve overlap for example bleeds off pressure at low RPM but builds more at high RPM. So your compression ratio + your cam are two main things that affect your cylinder pressure, that are different on everyone else's vehicle. That's why having them be close to them same from cylinder to cylinder matters more than what the actual number itself is.
Old Jul 29, 2005 | 11:44 AM
qman's Avatar
qman
Thanks jor, finally someone that has definitive data. And jor, is that range (100-250) applicable to all engines or does the range for a 300 added to the ranges for all other engines (302, 351, 360, 390, etc) cover that total. In other words, is it OK for one 360 to be like mine in the 108-120 and another 360 in the 180-190 and yet even another 360 in the 230-240.
Old Jul 29, 2005 | 10:27 PM
Cracker289's Avatar
Cracker289
Thats a pretty wide range to be definitive data!
As for your 360 compared to other 360's, it would depend on the cam, and the compression ratio, and whether or not the cam is advanced or retarded. If the engine was made during the smog years (73-newer) there is a good chance the cam has 4 degrees retarded ground into the profile.
Old Aug 1, 2005 | 12:37 PM
qman's Avatar
qman
72 360 completely stock engine except for the Pertronix I ignition and Ignitor coil. Can you tell me if my range of 108 to 120 psi is OK or not? The cam is stock.
Old Aug 1, 2005 | 10:21 PM
Cracker289's Avatar
Cracker289
Yes, that range is acceptable. 108 is 10% less than 120, so that is in the acceptable range.
Old Aug 2, 2005 | 02:47 PM
qman's Avatar
qman
Forget about the 10% for a minute. Are the numbers, 108-120 acceptable for a stock 72 360 engine or is my engine shot? Like I mentioned earlier, if all my cylinders read in the 60-65 psi range they too would be within 10% of one another but I'm gonna guess that 60 psi isn't considered acceptable. I would just like to know if the values themselves (i.e. 108, 111 x 3, 114 x 3, and 120) are pressures that would be considered a strong engine. Or is it that my engine should have higher or lower pressures? Or is it like jor reported above that since my cylinder pressures are in the 100-250 range, then it is OK?
Old Aug 3, 2005 | 01:05 AM
Cracker289's Avatar
Cracker289
Ok well usually you wouldn't expect all the cylinders to wear evenly, the fact that all 8 are within 10% of each others generally leads you to believe that they are relatively close to what they are supposed to be.
But you want a mathematical answer, so here goes. The atomspheric air pressure is 14.7 pounds. If your engine has 9:1 compression ratio, and the cylinder is perfectly filled with 14.7 pounds of atmospheric air, then you would have 132 psi once the piston reaches TDC.
However most engines do not have 100% effeciency, in fact 85% is considered pretty good, which would put you at 112 psi.
So I think your 108 to 120 range seems to fit pretty well.
