Aerostar Ford Aerostar
Engine Compression Spec
Old Aug 14, 2016 | 01:58 AM
SKaero's Avatar
SKaero
I did a engine compression test on my 1992 Aerostar 4.0L and came up with the following numbers:
#1 - 130
#2 - 142
#3 - 135
#4 - 135
#5 - 145
#6 - 130
While I can see that its well balanced I'd like to know what the original spec for the engine was so I have something to compare my numbers against. I haven't been able to find anything in any of the books that I have so if anyone knows please let me know. I'd also be interested in what anyone else has seen on there Aerostar's.
Old Aug 16, 2016 | 11:33 AM
93nighthawk's Avatar
93nighthawk
Ford does not give specs of compression for the engine, but here is what they advise doing.
Compression Readings — Interpreting
It is recommended the Compression Pressure Limit Chart be used when checking cylinder compression so that the lowest reading number is 75 percent of the highest reading.
If one or more cylinders reads low, squirt approximately one tablespoon of SAE 50 weight or equivalent engine oil on top of the pistons (6108) in the low reading cylinders. Repeat compression pressure check on these cylinders.
  1. If compression improves considerably, piston rings (6149) are at fault.
  1. If compression does not improve, valves are sticking or seating poorly.
  1. If two adjacent cylinders indicate low compression pressures and squirting oil on pistons does not increase compression, cause may be a head gasket leak between cylinders. Engine oil and/or coolant in cylinders could result from this problem.
Example Readings
If, after checking the compression pressures in all cylinders, it was found that the highest reading obtained was 1351 kPa (196 psi) and the lowest pressure reading was 1069 kPa (155 psi), the engine (6007) is within specification and the compression is considered satisfactory.
Old Aug 16, 2016 | 11:59 AM
SKaero's Avatar
SKaero
What I want to know is the overall heath of the engine, is there anyway of doing that?
Chisum5013
Feb 4, 2016 01:14 AM
zzjonze
1983 - 2012 Ranger & B-Series
Mar 30, 2010 06:06 PM
darsacal101
Feb 29, 2008 02:22 AM
Diggie
Aug 29, 2004 12:19 PM
Nod
Offroad & 4x4
Feb 13, 2000 04:26 AM
