windshield wiper issues
Old Oct 2, 2014 | 02:41 PM
derrickmauk1003's Avatar
derrickmauk1003
Windshield wipers are acting weird. They move real slow, like they take 10 min to make one swipe. Here is what I have tried.
Tried multiple wiper moduals under the dash
Hooked up hot wire from battery to motor and it started working but later went back to same issue.
Old Oct 2, 2014 | 02:53 PM
1986F150six's Avatar
1986F150six
Welcome to the forum, derrickmauk1003!
You checked the hot wire, but what about the ground?
Old Oct 2, 2014 | 09:42 PM
derrickmauk1003
I have not checked out the round but I will do so in the morning.
derrickmauk1003
I meant ground in the above post
Old Oct 3, 2014 | 09:19 AM
ctubutis's Avatar
ctubutis
You can go back and edit your post for ~1 month after you make it....
Old Oct 3, 2014 | 05:45 PM
Eddiec1564's Avatar
Eddiec1564
Sounds like the wiper motor is going bad or a connection between the intermittent modual .
When the wipers are going slow, try smacking(RUBBER MALLET or small wooden board) the wiper motor and see if it speeds up, loose magnets causes this sometimes.
Old Oct 3, 2014 | 08:24 PM
Jerry's red Ford's Avatar
Jerry's red Ford
wipers
I had the same problem when I started restoring my 1986 F250. I chased it down and found the ground wire broken or at least only one or two strands of the copper wire connecting in between the wiper switch and the chassis ground. I replaced the wire and everything started working as it should be. I think the foot portion of the emergency brake mechanism damaged the wire, because the break was very near the mechanism.
Best of luck, Jerry Reichert - Edgewood Washington
Old Oct 4, 2014 | 04:14 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The foot brake smacking the stop when you release it often damages the intermittent wiper governor.
Ford suggests not reattaching it to the bracket on the parking brake mechanism.
You will see it says "do not drop" or something to that effect.
I wrapped mine in foam rubber and zip tied it up behind the fuse block.
Old Oct 4, 2014 | 04:24 PM
Franklin2's Avatar
Franklin2
They mount the motor in rubber mounts to make it quiet, so that ground wire is just as important as the power wire.
Old Oct 4, 2014 | 04:52 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My truck has a ground wire from the wiper motor bolt to the intake manifold.
I'm pretty sure this is factory on my '87 truck.
Old Oct 5, 2014 | 07:50 PM
derrickmauk1003
My wiper motor is grounded to the intake manifold. Is there supposed to be a ground wire on the governor? Im looking for a wiring diagram for that portion of the setup.
Old Oct 5, 2014 | 10:01 PM
ctubutis's Avatar
ctubutis
Here ya go...
From the 1981 EVTM:
Old Oct 6, 2014 | 10:38 AM
1986F150six
Nice job, Chris! I would "rep" you, if I could!
Old Oct 6, 2014 | 05:34 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Everyone should have an EVTM...
BTW, if you have intermittent wipers there is a ground wire on the switch that must be connected or they won't operate.
oldbird1965
13
Nov 26, 2011 10:36 AM
RunRed
Mar 25, 2007 12:41 PM
Galaxie427
1983 - 2012 Ranger & B-Series
Jan 26, 2005 05:57 PM
AllFords1022
Mar 28, 2004 12:55 PM
