4x4 hubs
Old Sep 29, 2014 | 07:00 PM
rydavis's Avatar
rydavis
4x4 hubs
i need help..i installed all new front parts a month ago..new wheel bearings,upper an lower ball joints..new u joints on axel..and did both seals on axels on hub side and shaft side..i had 2 bad 4x4 lockings hubs..one seized and 1 plastic cracked..it was just a money issue..i finally put on the new hubs yesterday and and when i engaged the system..it seems to lock and work fine just riding arud my front lawn..but the problem i have is the driver side keeps jumping out when i disengage and go for a ride arud the block in auto...i did grease the heck out of them..i thot i did seat the new ring to hold the locking hub into the wheel hub..but now it happened again..did is miss a step or just too much grease?? any help wud b great..also is there a way to check if the axel needs to go in more so the 4x4 lock can have more depth to seat the new holder ring ?? anyone have this problem?? any help or suggestions wud b great as im losing my patients..
Old Sep 29, 2014 | 07:03 PM
rydavis's Avatar
rydavis
i have a 2005 ford excursion 6 litre diesel..with auto and lock hubs..just for yur info on my locking hub problem
Old Sep 29, 2014 | 10:13 PM
The2003Excursion's Avatar
The2003Excursion
Did you use stock replacements or aftermarket ones like Warn or Mile Marker?
jaysolomon
Dec 11, 2010 08:02 PM
JohnnyDiaz
15
Dec 19, 2009 06:38 PM
Estam
Apr 20, 2009 09:18 AM
rebel1803
Offroad & 4x4
Nov 22, 2008 09:29 PM
bored-68-ford
Jan 17, 2005 10:59 AM
