Sponsored by: Real Truck
4x4
Old Dec 4, 2010 | 06:50 PM
jaysolomon's Avatar
jaysolomon
4x4
Ok so I have a 2002 F250 SD CC 4x4. Ihave not had truck long and its my first 3/4 ton
I got stuck today and got out and was successfully able to lock the driver side hub in, but the passenger side would not lock in.
Anyone have any suggestions
Thanks in advance.
Old Dec 4, 2010 | 08:55 PM
REDSLED08's Avatar
REDSLED08
The hub wouldn't rotate or it rotated and would not engage?
Old Dec 4, 2010 | 09:23 PM
jaysolomon's Avatar
jaysolomon
the hub won't rotate
Old Dec 6, 2010 | 03:48 AM
REDSLED08's Avatar
REDSLED08
OK. These hubs have a tendancy to freeze up. About the only hope you have for that hub is to pop it off. If it's like my '01, you should be able to squeeze the two tangs on the lock ring together (by hand) and wiggle the hub out. Remove the O ring and drop the whole thing into a container filled with WD-40 or the like. Let it sit in there overnight, pull it out and begin trying to work the selector from AUTO to MANUAL. If you're lucky this will work. If not, check out eBay but beware...a lot of the hubs on there don't work either. This worked for one of my hubs but not the other. Once you get two working hubs on your truck again, the best way to keep them free is to periodically bend down and move the selector back and forth a couple times. Good luck. Hope this helps.
Old Dec 6, 2010 | 04:20 AM
SGnAZ's Avatar
SGnAZ
This will give you some more info
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Dec 11, 2010 | 07:34 PM
jaysolomon's Avatar
jaysolomon
thanks for the reply. I may just order some new warn hubs and be done with it.
Old Dec 11, 2010 | 07:43 PM
sotwclarinetguy's Avatar
sotwclarinetguy
What keeps it from rotating is this:
The o-ring around the dial deteriorates and bunches up, jamming the dial. You can disassemble the whole hub in about 3 minutes, and even change the offending o-ring (you can get them from agriculture dealers or hydraulic shops for pennies). Here is how to disassemble the dial part to get to that o-ring:
https://www.ford-trucks.com/forums/9...placement.html
These hubs are very serviceable, I am not really sure why everyone goes for other ones...
Old Dec 11, 2010 | 08:02 PM
BobbyDiesel71's Avatar
BobbyDiesel71
Try cleaning and lubricating Stock 4x4 hubs, first. That usually works for some extended amount of time. BUT in the end, BUY the Premium Warn manual locking hubs and be done with Fords AUTO HUBS(ESOF)
good luck!
danlyst13
Jan 31, 2015 10:58 PM
mjc3276
Jan 4, 2013 10:00 AM
nlfireblade
2004 - 2008 F150
Dec 8, 2009 12:20 PM
moarkmike
Offroad & 4x4
Jul 19, 2009 12:56 PM
Stroker01
Mar 7, 2004 08:15 PM
