Aerostar Ford Aerostar
New Front springs
Old Sep 25, 2014 | 04:36 PM
jetfiremuck's Avatar
jetfiremuck
New Front springs
Ongoing front end hitting bump stops, so figured that springs are now weak. I replaced the fronts with Ac delco 45h1046. What a difference!!!!. Front sits approx 1" higher than before and rides so much better. Front end had sagged quite a bit.
Old Sep 26, 2014 | 03:18 AM
xlt4wd90's Avatar
xlt4wd90
Did you also replace the dampers? Weak dampers will not properly control suspension motion, and can wear out springs faster.
Old Sep 27, 2014 | 05:10 PM
96_4wdr's Avatar
96_4wdr
Also high pressure gas shocks such as KYB Gas-A-Just, Koni or Bilstein only will stand up to the high center of gravity heavy rolly polly Aerostar
Makes the springs last far longer.
peenhead
Apr 15, 2025 05:05 AM
*2fords*
Jan 25, 2011 06:24 PM
jseim44
Sep 12, 2006 07:30 PM
just1me
Dec 3, 2005 01:12 PM
DT 466Man
Jan 4, 2005 03:08 PM
