front sagging
Old Oct 28, 2005 | 04:49 PM
just1me's Avatar
just1me
front sagging
the front of my truck is starting to sag a little the back is fine and sits right but the front looks like it has dropped down, could this be bad shocks or springs? and if its just the shocks what kind fit and what will interchange?
Old Oct 28, 2005 | 05:51 PM
ivanribic's Avatar
ivanribic
Shocks don't hold the weight of the truck, they only dampen the movement of the springs. If you have sag it will be caused by tired springs. You can either replace them or sometimes have them redone by a spring shop. I'd opt for new springs personally.
Old Oct 28, 2005 | 06:57 PM
Polkat's Avatar
Polkat
I had mine redone once, and it worked fine for a while, but it didn't take long for the springs to begin sagging again. New springs is best here, and these twin I beam trucks depend on correct ride height for proper front end alignment (in particular camber).
Old Oct 28, 2005 | 07:11 PM
just1me's Avatar
just1me
thanks
thanks, will any 73-79 f-250 springs work mine is a 76 f-250 2wd
Old Oct 28, 2005 | 07:31 PM
Mil1ion's Avatar
Mil1ion
Make sure you get replacement springs for an F250 with A/C.
They are slightly stiffer than a truck without AC.
Mil1ion's Avatar
Mil1ion
Weird !
Please remove post !
Old Dec 2, 2005 | 06:12 PM
springirl's Avatar
springirl
the hd springs that should fit in your truck are part # 43-498 which come with very little arc as do most front springs, the quick check is looking at the bump stop and see if it is pounded out, and if so get new, like most do, rearcing tapered leaves does not work well and you will have a very hard time getting any alignment again!!!! D
Old Dec 2, 2005 | 08:28 PM
ford390gashog's Avatar
ford390gashog
the front is coil springs not leaf springs.
Old Dec 2, 2005 | 08:40 PM
fordraceboy's Avatar
fordraceboy
the lowboy springs are differnet than highboy springs also... ooops! we are talking 4wd right? i just noticed gashog post...
Old Dec 2, 2005 | 09:28 PM
ford390gashog
he needs 76 f-250 2wd springs
Old Dec 3, 2005 | 11:28 AM
springirl's Avatar
springirl
sorry, i thought it was 4x4....oops
Old Dec 3, 2005 | 01:12 PM
just1me's Avatar
just1me
yea
yea its a 76 f-250 2wd with the 460 well came with a 460 has a 429 right now.
