Aerostar Ford Aerostar
Combination brake valve
Old Sep 21, 2014 | 05:16 PM
jetfiremuck's Avatar
jetfiremuck
Has any one taken one apart? If so does the little valve located deep in the valve body come out? I have a situation where ive the rf brake pads worn way down before the left side. This is after caliper, pad and rotor replacement. The rf wheel has more brake dust and i can feel a little pull to the right when I brake. I got a replacement froma junk yard and took it apart all came apart except the valve deep in the body. Pulling with a long nosed pliers didnt work.
Old Sep 21, 2014 | 05:48 PM
96_4wdr's Avatar
96_4wdr
The proportioning valve only controls front/rear brake pressure, more to front discs than rear drums. 70/30 usually.
The combination valve prevents the lose of front or rear brakes depending on where fluid pressure is lost. Vehicle will always have brakes at one end or the other.
Side to side brake lockup is caused by plugged lines. Front is usually the flex line is breaking down inside and gummy rubber is plugging the line. Replace both fronts, mine only lasted 12 years. Collapsed rubber line interior prevents brake fluid bleed back when brakes released, brake drags.
Brake fluid contaminated by water turns into strong acid.
Blow all the lines out with compressed air, brake cleaner then compressed air again. New fluid
Old Sep 25, 2014 | 04:27 PM
jetfiremuck
Replaced both brake hoses as suggested. Pedal feels a little different. Looks lik the ac drips on the hose mounting bracket creating rust and crud. Will keep you posted on he brake pad wear
Old Sep 25, 2014 | 04:33 PM
Don Naslund's Avatar
Don Naslund
It could be the caliper sticking. Have you overhauled the calipers?
Old Sep 26, 2014 | 03:25 AM
xlt4wd90's Avatar
xlt4wd90
Even without the AC dripping on the bracket, it naturally traps moisture by the sleeve that's supposed to protect it. On mine, the sleeve also cut into the brake hose:
https://plus.google.com/photos/11555...67774490549511
I modified the sleeve with a V-cut at the inside bend on the new hose.
Old Sep 27, 2014 | 05:13 PM
96_4wdr's Avatar
96_4wdr
Chevota_72
Dec 17, 2016 09:19 PM
texbigred1
May 26, 2015 07:01 AM
abarretto
Apr 28, 2010 04:29 PM
MNGolfer
Mar 22, 2004 06:14 PM
Old Ell
1978 - 1996 Big Bronco
Jul 27, 2003 12:22 PM
