HPOP problems
Old Oct 10, 2014 | 08:57 PM
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by trevorrules
ok I fixed it, it turned out to be a loose battery cable ... but it still should have started when it was at operating temp. ......that's the thing that makes me scratch my head
Things get heat soaked and heat created resistance. Then factor in a loose connection. So while the engine turned over fine cold. When warm, you would not get the full voltage needed to A. spin the engine over fast enough, B. the ECM needs 11volts for it to function correctly, C the glow plugs need at least 11Volts to function correctly, D. the IDM need 11volts to function correctly.
But it is too bad you didn't put a HPOP on for no good reason and still not fix the problem
Old Oct 10, 2014 | 09:22 PM
trevorrules's Avatar
trevorrules
yeah im glad I didn't cause if I did and it didn't fix it id prob put a sledge hammer to it
Old Oct 11, 2014 | 08:21 AM
carguy94's Avatar
carguy94
good job finding the problem and thanks for posting back
Old Oct 11, 2014 | 10:35 AM
trevorrules
no problem
ztodd377
Dec 19, 2015 04:58 PM
BILL.B
Aug 15, 2011 09:34 PM
Donald Becknel
19
May 24, 2011 11:25 PM
dzldude
Jul 30, 2008 05:20 PM
Badluck
Sep 24, 2006 03:36 AM
