diagnostic codes
Old Jul 14, 2003 | 06:00 PM
ddakota's Avatar
ddakota
Smile diagnostic codes
i now have a 1996 f 150 6 cyl .question i have a list of the obd codes 3 didgit codes ..after i have the numbers is there a web site i can go to to get the recommended repair ?? what size travel trailer can i handle with this 4.9 liter 6 ???thanks ddakota
Old Jul 14, 2003 | 06:25 PM
steve83's Avatar
steve83
diagnostic codes
OBD-II codes
There's no specific repair associated with most codes - they just tell you which system the computer THINKS there's a problem in. You have to determine if the computer is right and what the problem is. The Ford/Helm service CD (~$10 delivered off eBay) has all of the pinpoint tests for every code for every Ford truck & van made for the year that you buy (& lots of other info, of course).
The owner's manual tells how to figure your recommended trailer weight - it's VERY dependent on your specific truck, but you can go up to ~3,500 lb without much trouble.
Old Jul 15, 2003 | 10:13 AM
ddakota's Avatar
ddakota
diagnostic codes
to big six.... thanks for the reply ..so far my six is doing good..ddakota
Old Jul 15, 2003 | 08:46 PM
natewoz's Avatar
natewoz
diagnostic codes
The PCM "Computer" will illuminate your check engine light when the imput from it's sensors does not concur with the specs stored in its ROM memory. The PCM will not lie to you. If you are pulling codes, make note of which systems the code tells you- air/ fuel, emissions, brakes, etc. when you figure out what parts you need to look into, it's time to break out the fluke and the manual. What codes are you pulling if any?
Old Jul 16, 2003 | 07:51 PM
ddakota's Avatar
ddakota
diagnostic codes
to natewoz ..thanks for the reply ....went to autozone and they put their machine on for free got the 171 and 174 codes ..then loked it up and computer showed oxygen sensors..i took off the sensors made sure they were clean put them back on and check engine light is now off...my frist experience with computers on vehicles...enjoy reading all the replys and advise on this website ..ddakota
Old Jul 17, 2003 | 09:35 PM
steve83's Avatar
steve83
diagnostic codes
Even if the HEGOs were bad, you wouldn't be able to see it. If leaded gas has EVER been burnt in that engine, the HEGOs can be fouled in minutes, even though they look perfectly new.
But you didn't say exactly what the code definition was - just picking some words out of it (like "oxygen sensor") tells us nothing. You need to read & understand what the complete code definition says, and then analyze the system. A lean condition reported by the HEGO can come from an EGR valve stuck open, or a bad fuel pump. The HEGO can be perfectly fine and report a true problem - that doesn't mean you should replace the HEGO.
kbf1961
Oct 17, 2015 10:05 PM
JIM_C
6.2L V8
Sep 23, 2014 08:31 PM
ericnj75
Aug 27, 2007 04:21 PM
IM1096
Mar 29, 2007 09:02 PM
y2kexc
18
Jul 29, 2005 08:04 PM
