I have a Scangauge II that I used with my 6.0. Works great. Can anybody tell me where the codes are to reprogram it for the 6.2? Do I use the generic Ford codes on the Scangauge website?
I used the X gauge CANSF codes found on the Scan gauge website. These are used on vehicles MY 2008 or newer. On my F 250 6.2, I only used the trans temp. (Alt#4 code IIRC) The other codes seemed to apply to diesel engine monitoring. I had the scan gauge when I owned my F150 for trans temp monitoring. Even though my F250 has a productivity screen for Trans temp reporting screen, I like setting my SC II up for Average MPG, Trans Temp, Water Temp, and Volts. Depending when I am traveling I might do the air intake temp instead of Volts. I mounted mine on the rear view mirror for a quick look at the systems.
