1978 - 1996 Big Bronco
Can you use these keys?
Old Sep 14, 2014 | 05:46 PM
79-ford-f150's Avatar
79-ford-f150
So this is the best news i ever received, a lady i know contacted me and said her grandson NEVER came back to get his Bronco and left the state, but, he has the key and title, so she told me to come get it, she is filing for a abandoned vehicle title, since it has sat for about a year, but we have no key besides my 79 ford key which i lost, while trying to get a key for mine we noticed a 92 Ford truck key worked for my truck. Can you use a 79 Ford key in a 92 Bronco like the 92 key in a 79 ford or was that just pure luck and i need to cut a key for the bronco?
Old Sep 14, 2014 | 07:06 PM
351Cleveland C4's Avatar
351Cleveland C4
Huh?????????
Old Sep 14, 2014 | 08:46 PM
79-ford-f150
Wrote that fast and missed details, it's fixed.
Old Sep 15, 2014 | 05:00 AM
gatorfor88's Avatar
gatorfor88
The chances are you will have to get keys made. You lucked out once.
Old Sep 15, 2014 | 05:36 AM
79-ford-f150
We figured, but i wanted to ask before driving an bour to go find out my keys wont work, so i'll go get the title and have my key cutter cut ine for me. Thanks.
Old Sep 15, 2014 | 08:53 AM
jas88's Avatar
jas88
I use the same ignition key for my '91 F150 and my '74 F350.
Old Sep 15, 2014 | 12:35 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Go to a JY grab a $5.oo ignition assembly out of a 78/79 with a key in it (just tap the 3 notch outer ring off in a counter clock wise direction and remove and un plug it).
Un plug the old ing and just plug in the new TJ one, you can even leave it hanging under the dash, wala no key to be made.
While you are there pop (slide the U shaped lock tab from the back side) the door locks so one key matches door locks and ing. Look for a locking glove box too...2 phillips screws hold it in.
Old Nov 22, 2014 | 10:36 PM
Rscottc's Avatar
Rscottc
Only one side of the ford key works. If you have two fords you can have a key duplicated cuts from one truck, flip key over and have cuts from other truck duplicated on that side. Same for door locks. This works with 5 pin or 10 cut. Ignition key that unlocks door also is a 10 cut.
Old Nov 25, 2014 | 02:46 PM
Encho's Avatar
Encho
The Southernmost Mod
Hmmm, first time I read this, it could come quite handy for me around these parts, I'll try to dig a little more into this.
toys4dlr
Sep 21, 2024 06:44 AM
Mark 42
Mar 9, 2018 02:28 PM
jake22si
1997 - 2003 F150
Oct 27, 2014 12:18 PM
Buck 1
2004 - 2008 F150
Aug 13, 2008 05:22 PM
PyroManiak
Aerostar
Nov 20, 2001 03:03 PM
