Injector reading open
Old Sep 12, 2014 | 04:59 PM
WoodHacker's Avatar
WoodHacker
I used these instructions to check my injector solenoid resistance. 6 of mine read in the 3.6/3.7 ohms. #7 read 4 ohms. #2 read infinity (open).
How should I proceed from here?
I'm an artist, not a mechanic, but I've done things like replaced an engine and a couple of transmissions so I am not helpless. Just clueless
1999 7.3 power stroke super duty. My first diesel.
Old Sep 12, 2014 | 05:15 PM
Pikachu's Avatar
Pikachu
Pull the valve cover outer wiring harness connector and recheck it from there. If it's open there as well, pull the valve cover off and make sure the inner connector is seated. Start with that, and see what you come up with.
Old Sep 13, 2014 | 01:51 PM
Tugly's Avatar
Tugly
Great job finding the thread and using it!
The most common cause of your problem is a bad Under Valve Cover Harness. You can test the continuity from the valve cover connector before diving in, but the UVCH problem is overwhelmingly common. Some people do the fifty-cent mod (install a spreader on the UVCH locking tab), but I've seen a few of those fail. If you enjoy wrenching on a diesel and want to try it for almost no cost - do the mod and try your luck.
I tried it on two trucks, and they both failed. I now preach "Replace both UVCHs and be done with it."
Old Sep 15, 2014 | 10:41 AM
WoodHacker's Avatar
WoodHacker
FIXED
I proceeded with your suggestions and when I started to lift the valve cover gasket from the head, the wiring harness plug fell away from the gasket connection. That was the problem. Rather than plug it back in and hope for the best, I bought a new harness from NAPA ($70 China made) and installed it. TRUCK RUNS GREAT NOW!
This new harness is hardwired to the inside of the gasket and the wires appear to be smaller than the one I removed. I didn't care for the smaller wires.
Thanks for the help
rollinblackcloud
May 1, 2014 09:10 AM
F350-6
Jun 24, 2012 08:32 PM
blrman1962
May 28, 2007 06:40 PM
03 SuperDuty FX4
Jun 20, 2005 08:07 PM
krzyk26
Apr 3, 2005 04:19 PM
