another crank no statrt
Old Sep 16, 2014 | 08:19 AM
  #61
BryanStein's Avatar
BryanStein
Originally Posted by Rusty Axlerod
Thanks Brian , yup you can check the IPR on the workbench by reading across pins A&B, for sure the way to go if you have the IPR out of the truck. The idea here is it's quicker/easier to check at the PCM connector than getting behind the turbo and getting the meter leads on the IPR connector pins.
The yellow/red stripe wire is the ground side, the other side is hot all the time (battery voltage) so the other lead goes to the + on the battery with the key on to close the circuit.
Oh, now I understand. I was pulling the pcm connector and checking the appropriate pins (female) on the wiring harness without going through the battery. This will also confirm the wiring harness for the ipr. Then, it you see a problem, then you pull the ipr to see if it's the ipr or the wiring.
But, let me say me and electricity don't get along. I usually blow a fuse or two when I get into electrical systems.
Old Sep 17, 2014 | 06:21 PM
  #62
f350project's Avatar
f350project
Got around to doing the compression check via the cranking and there is stark difference between the linked video and mine. I think my batteries needed a little more of a charge so i will try this again and then confirm which cylinder(s) is bad. I really don't like how it sounds.
Base engine problem maybe?????
https://www.flickr.com/photos/31331176@N06/15085752279/
Old Sep 17, 2014 | 06:31 PM
  #63
BryanStein's Avatar
BryanStein
It just needs to sound even without speeding up and slowing down rpms. It will speed up when it hits the cylinder or two with poor compression. It will run and crank with on bed cylinder. I don't know if it will with two bad cylinders, but think it should.
Old Sep 17, 2014 | 06:40 PM
  #64
f350project
Is the video clear enough for you to give an opinion on the crank? It was slower but had a whop whop whop sound to it. Not sure if that is a dead cylinder or not. It did not speed up or slow down however.
Old Sep 17, 2014 | 06:57 PM
  #65
BryanStein's Avatar
BryanStein
I assume you're talking about the video on flicker.
I thought the batteries sounded very strong. There was a slight "speed up" that sounded like one cylinder might be weaker, but it wasn't bad and you really had to pay attention to notice it. I've heard then much worse that were running, but those were on trucks with much weaker batteries. Weak batteries will make a weak cylinder sound worse because it won't spin the motor as fast, causing the "speed up" to really stand out. I don't think that's your problem, but you could drain the batteries a little and see if it gets worse.
Old Sep 17, 2014 | 08:12 PM
  #66
f350project
Yes the flikr vid. I've watched it many times, I just don't know. I'll have to get the compression of each cylinder just to make sure cause it's still not running. This thing has me stumped
Old Sep 17, 2014 | 08:30 PM
  #67
BryanStein's Avatar
BryanStein
I don't think compression is your problem. I was thinking you needed to monitor fuel injection pulse width (FPW) as I was skimming some of the thread because it sounds like your getting just enough fuel for it to want to crank. Well, there it was in post #5. Anthony suggestedmonitoring FPW and see if that points you to something.
I know Torque Pro can monitor FPW.
Now, in making that statement, I've reached the limit of my knowledge. I should document what my FPW is so I'll have it if needed.
Old Sep 17, 2014 | 08:31 PM
  #68
Rusty Axlerod's Avatar
Rusty Axlerod
I agree F350, it has a little bit of speed up, slow down to it. Sounds like there might be a little something going on there. Getting some numbered would confirm or rule it out much better. Good thing is it's not crazy sounding. I forget, did you do a bubble test? It's just cranking with the jumper (so the fuel pump doesn't run) and watching in the upper fuel filter bowl (filter and cap removed) for bubbles. If an injector is leaking, the air from compression will be forced through the leaking injector and through the lines back into the filter bowl.
Old Sep 17, 2014 | 08:45 PM
  #69
f350project
Yup did a bubble test after I replaced the injectors. Even they were new I wanted to make sure the injector seat cups were still good and providing a good seat/seal.
I'm not sure if I can monitor fuel pulse width with ForScan pretty sure I can with scan gauge though.
Doesn't it need to be running to monitor that though?
Say I do have a problem with FPW hoes does one fix that?
Old Sep 18, 2014 | 05:32 PM
  #70
f350project
Question:
A substantial loss of compression in one or more cylinder would have signs of blowby via the oil fill tube?
When one or more cylinders lose compression does the fuel dilute the oil?
Old Sep 19, 2014 | 07:02 AM
  #71
BryanStein's Avatar
BryanStein
Question:
I'm no expert, but I think only when the compression is so bad that you don't get the deisel to ignight would you dilute the fuel.
If most of the cylinders have lost compression, the motor will spin very fast while cranking. You need some compression numbers. I don't know what they are supposed to be.
usmarine1979
Jun 2, 2016 11:27 AM
anvez19
Feb 25, 2015 07:15 PM
f350project
Dec 23, 2012 01:10 PM
roodet1
Jan 6, 2010 10:02 AM
brickie
Mar 4, 2008 07:08 PM
