Flash question?
Sep 18, 2014 | 03:24 PM
Flash question?
I used to have a BullyDog GT tuner but now I got a SCT X4 with some custom tunes from Matt @gearhead and I just got off the phone with QuickTricks to get a Looney file and the guy told me that I should have my computer in my truck reflashed as Bullydog leaves remnants behind and I should have it reflash before loading new files as they won't work correctly. Gearhead says otherwise they say just clear the transmission memory because its a learning tranny. Does anybody know the true answer?
Sep 18, 2014 | 07:39 PM
Certified Thread Hijacker
Bullydog is a piggyback style tuner.
If it helps everyone sleep better you can either:
Reset the KAM with the SCT tuner to clear all adaptive learning
or disconnect all 4 cables from the batteries, turn the headlights on and leave for approximately 20-30 minutes to drain the computers.
I would speak to Vivian at Quicktricks and not someone else, she knows what's up.
For me personally the Looney Tune is way more brutal than the SRL, but the SRL is more daily driver friendly.
Josh
Sep 19, 2014 | 08:32 AM
Clear the KAM with the SCT, it's what I had to do when my transmission learned something bad.
Vivian does know her stuff, she probably also reminded you to update your SCT and why.
Sep 19, 2014 | 08:57 AM
Ok I cleared the KAM, and everything seems to be ok. Now my egr doesn't work. Is this apart of the programming?
Sep 19, 2014 | 09:06 AM
Quote:
Originally Posted by
ves83
Clear the KAM again with the truck up to temp, 190 degrees or so, perform the VGT relearn.
https://www.ford-trucks.com/forums/6...ml#post4956068
The truck does some more learning during this process. It should get things back to normal sooner.
Sep 19, 2014 | 09:36 AM
I just read that post at what point to I put the tuner back on the truck after all of this is done?
Sep 19, 2014 | 10:40 AM
ves83
-Make sure the truck is hot
-Put the tune on or leave it on if it's already tuned
-Reset the KAM with the SCT
-Perform the VGT relearn
rwrogers
Jun 13, 2019 10:57 PM
Sparky83
Aftermarket Products
Aug 31, 2015 07:41 PM
WillyD85
Jan 12, 2013 07:52 PM
036.0stroke
Jun 12, 2011 09:52 AM
jdadamsjr
May 11, 2009 04:43 PM
