another crank no statrt
Old Sep 11, 2014 | 04:01 PM
f350project's Avatar
f350project
All verified
Originally Posted by Super Duty Service
If its sputtering,, it's gotta be a fuel issue. Did a line get bent or crushed? Maybe something is clogging the banjos or in the upper fuel housing. I'd pop off the pass banjo and make sure fuel is flowing koeo. How did the filters look when it came in? You could pull the ebp sensor n throw shop air and listen at the tailpipe.
It does seem like it being fuel starved but I have a mechanical fuel gauge at the regulator that shows a constant 60+ psi KOEO and while cranking. prior to that I verified fuel flow at both banjo fittings and fuel pissed everywhere from each side I also have 6.4L banjo installed
Here is a video of me cranking. I took off the exhaust to eliminate a CAT clog and removed the air filter for the same reason. I did notice ICP takes a while to build pressure but does build pressure then you notice it jumps to 10K+/IPR also does some funky jumping around.
https://www.flickr.com/photos/31331176@N06/15024260878/
Old Sep 11, 2014 | 04:02 PM
Per4mance's Avatar
Per4mance
Sounds like it's air bound and has a weak starter/batteries to me
Old Sep 11, 2014 | 04:26 PM
f350project
Like air in the HPO system? I've been cranking it for like 3 days straight each time charging the batteries overnight (which are brand new btw) and the starter is also brand new OEM not reman.
I'm about to blow this truck up.
Old Sep 11, 2014 | 06:49 PM
mustang_309's Avatar
mustang_309
Have you tried a new ICP sensor? In the video the ICPV's stayed at .25 then suddenly jumped over 1.0 when it tried to start and at a couple of points dropped to zero.
Old Sep 11, 2014 | 07:04 PM
mustang_309
Also on your scan tool it is set up to read KPA for the ICP actual and desired so its not actually hitting 10000 PSI, more like 1450, but the problem I see is it takes way to long for the ICPV's to come off of .25 then all of the sudden it pops over 1.0 and immediately tries to start but then the ICP drops to zero. If you can set it to read PSI it will make it easier. Has there been any work done to this like an oil cooler?
Old Sep 11, 2014 | 07:11 PM
f350project
Yes oil cooler was just changed. When I changed the oil cooler I refilled the reservoir and after the first day of cranking I removed the brand new IPR valve to make sure no debries had gone thru the system cleaned it and put it back on.
Old Sep 11, 2014 | 07:28 PM
mustang_309
And what about the items highlighted in red?
Old Sep 11, 2014 | 07:33 PM
f350project
It's a new ICP sensor from the local Ford dealership. I don't know why it jumps around like that. The ICP value I thought was in PSI I'll have to check that out makes sense since it's a 4000psi pump. Regardless if it's and ICP problem it still does the same thing with it unplugged
Old Sep 11, 2014 | 07:39 PM
f350project
ICP volts
Damn I took the video and didn't notice the ICPv drop to zero. Could that be an indication that there is air in the HPO system? If so how do I get it out. I've been cranking this thing for a minute
Old Sep 11, 2014 | 08:10 PM
Per4mance's Avatar
Per4mance
Lets back up a minute, did you ck the connector to the ICP ? I'll bet it's fubar if the readings are jumping around.
Old Sep 11, 2014 | 08:22 PM
f350project
It's a new pigtail. Properly done. Verified wiring according to info on this forum. Looks sound unless there is something I am missing.
Old Sep 11, 2014 | 09:07 PM
mustang_309
I realize you said the pigtail was properly done but it wouldn't hurt to check just to be sure you have a connection on both sides of the splice, if you crimped part of the wire insulation and not just the conductor you may not be getting a good clean signal, because it is acting like the signal is intermittent. And if you watch the video you can see the ICPV's hang at .25 and the IPR% is at 84 and as soon as the ICPV's jump over 1.0 the IPR% drops into the 40's - 50's and it attempts to start then the ICPV's drop to zero shortly afterwards and the IPR% goes back up.
Old Sep 11, 2014 | 09:42 PM
  #28
f350project
I will definitely check it out. Thanks. With the ICP sensor disconnected it acts the exact same.
Old Sep 11, 2014 | 11:15 PM
  #29
BryanStein's Avatar
BryanStein
How can you measure 8k and 10k of hpo? That's not possible. As Elmer Fudd said. Sometime awfwy scwey is gowing on awound here.
Check the icp wires going into the pcm. You'll need the diagram. It's on here somewhere. I think I have it digitally if you can't easily find it, pm me and I'll email out to you. Others will need to chime in on what volts and ohms are proper. Wiggle the harness when checking it.
If said icp, harness and pigtail are good, is it possible the check valves in the oil rails aren't letting the hpo oil reach the injectors? Maybe something else in the oil rails is dead heading the hp oil intermittently before getting to the.
Can you swap a known good ficm or pcm?
The swings in the icp suggest it's not an ficm issue.
Check the variance in the icp when the icp is unplugged. If the icpv and pressures swing the same way when the icp is unplugged (it likely is because the truck acts the same) it's in the pcm or harness or pigtail and has nothing to do with the Ipr.
Old Sep 12, 2014 | 07:36 AM
  #30
f350project
I've been thru the wiring and think its good. I do need the diagram for the PCM to ICP etc. I will have to re-look at the computer and check the setting for PSI that thing isn't putting out 10000+psi I was more concerned with the ICPv. The truck acts the same with the ICP disconnected. The ICP was miss wired and I corrected it could that have shorted out the PCM?
I wasn't aware the HPO rails had check valves?
If I change the PCM I have to get the exact same part number that is installed right or can I just throw another same yr PCM and it'll run?
