parking lights
Old Sep 5, 2014 | 03:32 AM
tinaheels's Avatar
tinaheels
parking lights
after 20 or so minutes my parking lights begin to flicker,what would cause this ?.head lights are fine. could it be a short or a bad switch ?
Old Sep 5, 2014 | 06:25 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Do both sides do it, or just one? What about the side marker lights? Are they okay?
The marker lights and parking lights are all on the same circuit. If it's a switch problem then all of them should be acting up.
If just the parking lights flicker, I would first, check the bulb sockets, be sure the contacts are clean and free of corrosion and the contacts aren't weak and are making good contact with the bulb. Next check the ground connection. They are grounded to the radiator support. Be sure the connection is clean and tight. Check the wiring for any damage and it probably wouldn't hurt to put new bulbs in.
Old Sep 5, 2014 | 07:45 AM
1978f-250's Avatar
1978f-250
First, do all the things Mike suggested. If you can move the bulbs around in the socket and make them work or go off maybe you need new sockets. I just ordered a pair yesterday from here: Front Park Light Socket-Broncograveyard.com
I have lights that work most of the time but sometimes not. Yesterday I took them apart and found the bulbs to be very loose in the socket. Apparently that's my only problem.
Good luck solving yours.
Dennis
Old Sep 5, 2014 | 08:40 AM
tinaheels's Avatar
tinaheels
every parking light,side marker, clearance light & license plate light do it
Old Sep 5, 2014 | 08:44 AM
fmc400's Avatar
fmc400
MSEE
All these lights are on the same circuit (BROWN wire) and are sourced from a separate pole of the headlight switch (vs. power to the headlights). If the headlights do NOT exhibit a failure, I would suspect the headlight switch in this case. An internal failure within the headlight switch could affect the parking lights without affecting the headlights. If the headlights acted up too, the diagnosis would be different.
Old Sep 8, 2014 | 04:17 PM
tinaheels's Avatar
tinaheels
new switch fixed teh problem. thanks ya'll .
Old Sep 8, 2014 | 05:05 PM
fmc400's Avatar
fmc400
MSEE
Glad to hear you got it worked out.
Old Sep 8, 2014 | 06:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Despite what Bronco Graveyard claims, these will NOT fit 1973 or 1974 F100/350's before serial number T80,001.
Bronco Graveyard also failed to list all the other applications for this socket.
D1FZ-13234-A .. Plastic T/S Socket / Reproduced
1971/73 & 1977 Pinto / 1974 F100/350 from serial number T80,001 / 1975/78 LTD / 1975/79 F100/350 / 1975/91 Econoline / 1978/79 Bronco.
And as a taillamp socket for 1974 F100/350 Stylesides from serial number T80,001 / 1975/79 F100/350 Stylesides / 1975/91 Econoline / 1978/79 Bronco.
1973, 1974 F100/350 before serial number T80,001: The park and tail lamp bodies are metal, the individual plastic lenses screw to the bodies that have the sockets swagged into them.
Andrew Fraser
2015 - 2020 F150
Jun 4, 2018 02:52 PM
wrd0225
Sep 30, 2014 10:53 PM
$Simpleman76
Mar 22, 2007 06:29 PM
74f100gg
Apr 14, 2005 12:41 AM
Aubrey3
1983 - 2012 Ranger & B-Series
Jan 11, 2005 09:50 PM
