Rear running lights not working
Hello all!
I was stopped by a fellow 150 driver about my not being on.
When i got home i checked and my front lights all work fine. But my lights and brake http://www.tomtop.com/2Pcs-5W-Super-Bright-LED-Car-Fog-DRL-Daytime-Running-Lights-Waterproof-Ultrathin-36-Chips-Red-K918R.html were not working. When i press on the my lights due turn on but other than that they do not.
Now i looked at the bulbs for the license plate since its dark and thats all i really wanted to do tonight and i noticed that both are burnt out. I also saw a lot of corrosion on the one bulb and the place you would put the bulb.
So my question is would both bulds being burnt out cause the running brake lights not to work? Or when i go buy new bulbs should i also get a fuse incase that isnt the fix?
Also how do i clean the corrosion out of the socket? Just like a q tip and ?
Also where is the for the license plate and such. I have gone through my owners manual and have not found anything in fuses that would say lights to license plate or back running lights
Thank you all!
Andrew
PS this is a f150 2015 XLT
Thank you all!
Andrew
Hello all!
I was stopped by a fellow 150 driver about my lights not being on.
When i got home i checked and my front lights all work fine. But my license plate lights and brake running lights were not working. When i press on the brake my lights due turn on but other than that they do not.
During the night, in automatic mode, the headlights, signal lights, tail lights, and plate lights come on. You can also turn the head light switch to the "headlight" position to get this to work.
You can use contact cleaner to help remove the existing corrosion. However, my experience has not been so great once corrosion takes hold...even if I clean it off.
Kevin Peck
03-01-2018 10:21 AM
steuspeed
07-29-2016 04:12 PM
