4R75E Trans fluid,,,,,,,
Old Jun 15, 2024 | 06:31 PM
moorefc's Avatar
moorefc
Deleted...
Old Jan 9, 2025 | 09:02 PM
#Fordwins1's Avatar
#Fordwins1
1st Gear
Just curious if I can use Mercon LV on the 2006 Expedition with the 4R75E. Owners manual calls for Mercon V
Old Jan 10, 2025 | 07:21 AM
moorefc's Avatar
moorefc
See https://www.ford-trucks.com/forums/1...-for-e40d.html post 18, for instance.
Old Jan 10, 2025 | 05:00 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You can use whatever you want. Just know that if you use MERCON LV where MERCON V is required you will need a new transmission very soon. I recommend having a new trans on hand before installing MERCON LV.
Old Jan 14, 2025 | 10:16 PM
Redim7's Avatar
Redim7
6th Gear
Originally Posted by Mark Kovalsky
Didn't Mark Kovalsky post just about your post? And maybe provide some insight?
This Motorcraft AT FLUID CHART will answer too many questions about what oil you must to use...
File Type: pdf
Old Jan 14, 2025 | 10:17 PM
Redim7's Avatar
Redim7
6th Gear
File Type: pdf
Old Jan 14, 2025 | 10:26 PM
Redim7's Avatar
Redim7
6th Gear
The AT FLUID CHART (MOTORCRAFT)
Originally Posted by alumcanTandThd
Thanks for the suggestions.
The local auto parts stores that carry Motorcraft brand oils/ATF, NONE had a "4" or that "XT-10-QLV" printed anywhere on the bottles.
Advanced brand ATF has "LV4" on the label. Wal-Mart's brand has the "LV4" on their label. I don't want to mix discount brands with the factory fill, since I don't know anything about them.
I don't understand why the Owner's Manual says to use Motorcraft Mercon LV ATF4. Then the factory Service Manual says to use Motorcraft Mercon LV ATF XT-10-QLV. Two different Ford Dealers say they never heard of the "4" or the "XT-10-QLV". Both stressed, Motorcraft Mercon LV in the 4R75E trans.
I just want to make sure to get the right fluid.
How do I get ahold of the resident trans expert Mark Kovalsky?
EVERY vehicle I have ever had since the '60's, that has a auto trans, I've welded a pipe nipple/collar on the pan for a easy drain plug. I have several made up ready to weld on, laying in a drawer.
Thanks again.
This AT FLUID CHART answer all questions!
Old Sep 26, 2025 | 05:31 AM
Bejazee's Avatar
Bejazee
3rd Gear
LV fluid
Hi Tech transmission, rebuilt the tran in my 2008 F150, 4r75e. I was told they use LV fluid as there is no internal difference in my 08 and my 14 E350 which specifies LV fluid. It is just that the fluids V and LV are not compatible. With a complete rebuild there is no cross contamination.
I would like to know if this rings true to Mark K?
Thanks
Old Sep 26, 2025 | 06:29 AM
Mark Kovalsky
I left Ford in 2007. I have no idea what's in a 2008 or a 2014.
Old Sep 26, 2025 | 03:37 PM
Bejazee's Avatar
Bejazee
3rd Gear
Thanks for the reply Mark. Maybe some transmission builders will chime in.
SoCalAngler
22
Jan 15, 2025 09:35 AM
TXSailor
Jul 22, 2010 08:08 AM
fordmerc
1997 - 2003 F150
Jul 15, 2009 10:59 AM
bubbasz1
Nov 10, 2008 12:29 PM
Kenny Bonnell
1997 - 2003 F150
Jun 24, 2005 10:58 AM
