Which thermostat?
Old Aug 31, 2014 | 08:50 PM
Vashon Islander's Avatar
Vashon Islander
Which thermostat?
I'm running a .030 over 1972 360 in my 67 F250, I have a 160 degree thermostat in it and it never even makes it up into the normal or "white zone" on the temp gauge. Should I be running a 170 or 180 in it?
Old Aug 31, 2014 | 11:03 PM
HIO Silver's Avatar
HIO Silver
Factory gauges are notoriously inaccurate. If it truck isn't overheating, then stick with what ya got.
But accurate information is worth its weight so think about installing a real set of gauges (Autometer, VDO, etc.). Re-evaluate after.
Old Sep 1, 2014 | 12:05 AM
351Cleveland C4's Avatar
351Cleveland C4
I'm running a 195 thermostat and it gets right to the beginning of the normal zone.
Old Sep 1, 2014 | 04:14 AM
jowilker's Avatar
jowilker
180º is what came from the factory. I think there is some misconception about thermostats, the temp is where they open not what the running temp is. If it opens at 180º and the system is clogged or dirty it is not going to keep it from getting hotter and boiling over.
John
Old Sep 1, 2014 | 11:31 PM
FECruzer69's Avatar
FECruzer69
I agree that it may just be the gauge or sending unit. My engine had a 195 degree stat in it. After I rebuilt the engine it would read near the high end of the Normal range with that stat. I changed to a 160 degree stat and the gauge would run just below the middle with the 160.
My engine actually was quite hot with the 195, but not overheating.
Old Sep 2, 2014 | 12:48 AM
Tedster9's Avatar
Tedster9
Why is there such a range in temps in thermostats, anyway?
Old Sep 2, 2014 | 01:07 AM
montana_highboy's Avatar
montana_highboy
160 is a tad bit low for a street driven motor....oil temps generally run 30 degrees higher than coolant temps, and you want oil temps to reach a minimum of 212 to boil of contaminants....a 160 degree stat won't quite get you there.....sludge build-up will proceed....
180 degree T-stat minimum is my recommendation, it's a nice compromise between the factory 195 and the rodders 160.
Old Sep 2, 2014 | 02:10 AM
Thed's Avatar
Thed
185 is the sweet spot IMO. Running temp will never get to 200 with a properly-operating coolant system but it will remain hot enough for oil to keep temp and combustion temperatures to remain efficient.
Old Sep 2, 2014 | 11:07 AM
351Cleveland C4
On my engine, running a 195, head temperatures run right around 210. Oil temp the same.
Old Sep 2, 2014 | 11:31 AM
Rasputin53's Avatar
Rasputin53
Interesting. This is the next silly $3 part I need to swap out before it leaves me on the side of the road. The curse of a low mile original.
Old Sep 3, 2014 | 07:01 PM
JEFFFAFA's Avatar
JEFFFAFA
John
2X John. While a 192 degree stat won't let an engine run at 180, neither one designates the eventual running temp. Lets say an engine has a normal running temp of 210 degrees. The 180 stat may take that engine a tad longer to reach that 210 degrees. But it still will. I vote for 180 stat. I would have anyways but Montana brought up a point not thought of. Rep'd ya for it Montana.
Old Sep 3, 2014 | 08:15 PM
ultraranger's Avatar
ultraranger
Jowilker is correct. The rating of a thermostat; 160, 180, 195, etc., is the cracking temperature --the temperature the thermostat begins to 'crack' open (within plus or minus 3-degrees).
It will take another 15 to 20 degrees, above its rating, before the thermostat will be fully open.
Old Sep 3, 2014 | 09:56 PM
nickgti's Avatar
nickgti
I always grab a 180 then go from there. Gives a good all around base.
Old Sep 4, 2014 | 07:39 AM
6t6merc's Avatar
6t6merc
I installed a 195* just to test the heater core. I get great heat now, so no need to install the "new" Chinese core. I got the same results as FECruzer69, which I think are not dangerous, but do give me some concern.
Eric
Old Sep 4, 2014 | 10:56 AM
orich's Avatar
orich
I run 180* in every vehicle since the 1960's when read about what one of the reasons was for the built up of sludge. As montana has said.. also
Orich
Wolf82636
Mar 8, 2019 08:19 PM
dyoungen
Nov 29, 2009 09:37 AM
jdlongmate
Feb 27, 2009 01:46 PM
BigNiner19
2004 - 2008 F150
Sep 2, 2008 04:19 AM
handx2
Feb 25, 2004 12:12 AM
