Simple engine temp. question
Old Feb 26, 2009 | 01:25 PM
jdlongmate's Avatar
jdlongmate
I've finally got new mechanical gauges hooked up and my engine (390)temperature gauge is showing a steady 160*F when fully warm and moving down the road.
This seems like its running a little cool, right? Should I change the thermostat for a different temp range? If so, which type of thermostat should I put in it? Thanks for any advice...
Old Feb 26, 2009 | 01:50 PM
slinger34's Avatar
slinger34
Thats on the cool side.switch it out for a 190. That is what i have in my truck. No problems with it.
Old Feb 26, 2009 | 02:18 PM
Bear 45/70's Avatar
Bear 45/70
If you desire is for performance the 160° is good. The 190° is a emissions thing and does not help power building.
Old Feb 26, 2009 | 02:43 PM
jdlongmate's Avatar
jdlongmate
Thanks for the advice. I really just want to make sure that running at 160° is not going to cause any more wear and tear on my motor than running at a warmer temp. If that even makes any sense...If not, I'll just leave it where its at.
Old Feb 26, 2009 | 03:52 PM
jdlongmate's Avatar
jdlongmate
I found the answer on another post here, for some reason the first time I tried searcing for similar posts it didn't return anything useful (must have needed to list by relevancy)
https://www.ford-trucks.com/forums/8...-too-cool.html
Thanks again
Old Feb 26, 2009 | 10:56 PM
Hypoid's Avatar
Hypoid
It always take me a few minutes to dig up this post: https://www.ford-trucks.com/forums/s...2&postcount=41
But I remember the thread.
Old Feb 27, 2009 | 10:16 AM
dinosaurfan's Avatar
dinosaurfan
Wink too coooooold
JD, the 160 'stat is way too cold. The engine may run just fine like that, but you'll get 4 times as much wear as you would if you ran it at 190 or 200. It has to do with the coefficient of friction of aluminum on an iron bore, combustion residue, and other stuff. The easiest way to think about it is to remember that your engine is a heat exchange device. The fuel you burn has a certain amount of heat in it. The more of that heat you pull away from the pistons by sending it to the radiator, the less power and fuel economy you will have. FWIW, I run a 205* 'stat in all of my stuff. DinosaurFan
Old Feb 27, 2009 | 10:57 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Not to pick, but yes, it's good for performance, if you are USING all the power of the engine all the time and the cylinder bores (or more specifically, the pistons) get nice and hot and stay that way all the time.
If it's a daily driver, 180 is best.
Old Feb 27, 2009 | 01:46 PM
Bear 45/70's Avatar
Bear 45/70
I agree with your statement.
john jamieson
Dec 1, 2016 06:52 AM
chrislynn5
May 1, 2016 07:04 PM
trukerdanz
1983 - 2012 Ranger & B-Series
Apr 2, 2016 09:07 AM
Craig46
1947 and Older Ford Trucks
Oct 26, 2015 07:32 PM
Blackwaterforge
15
Jul 14, 2010 10:04 AM
